11-08-2020
12:24
12:57
11-08-2020
12:24
12:57
My charge 3 totally died. Blank screen, no lights at all. No smiley face no vibration. It won't sync. I've tried restarting but it doesn't responded to anything. Help
11-11-2020
06:28
10:07
11-11-2020
06:28
10:07
@Donnanixon1 Thanks for stopping by!
Let me help you with your unresponsive Charge 3 and thank you for troubleshooting this issue. I am not sure if this is a charging issue or a display one so I would like to suggest you try the following:
Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help your device charge.
Let me know how it goes.
Best AnswerAfter cleaning contacts and plugging it in for a few hours, all it did was made the fitbit hot to the touch. What should I try next.
Donna
08:49
10:07
11-18-2020
08:49
10:07
@Donnanixon1 thank you for the update.
This isn't an expected behavior for your tracker so I have created a ticket so our Support team can further assist you via email.
