07-12-2019
09:00
10:55
07-12-2019
09:00
10:55
Since I "Upgraded" from a Blaze to charge 3 , I have a number of issues, I don't know if one off or known issues , one repeating issue is total lock-up with corrupt graphic a reset cures this for a while . but my main niggle is the brightness is appauling I cannot see the time in any form in daylinght/sunlight even on the highest brightness level. I have seen a number of people saying the same thing , is this to be resoved or should i just give up? . I refuse to wear another watch just to tell me the time when im out and about. Has anyone managed to cure this . I guess its a software issue or a restiction so the battery life can be extended beyoond other watch capability at the sacrifice of poor visual display.which is a good selling point.
07-18-2019 12:01
07-18-2019 12:01
Thanks for following the suggestion I provided to you @york1000! I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you with.
07-13-2019 07:54
07-13-2019 07:54
Welcome to the Community Forums @york1000! I am sorry to hear that you are going through this situation. Rest assured that I will do my best to help you.
Have you checked if your tracker's brightness is the one you selected? If you haven't, I recommend trying the following from your Charge 3:
Let me know the outcome, I'll be around.
07-17-2019 09:04
07-17-2019 09:04
07-18-2019 12:01
07-18-2019 12:01
02-26-2020 19:15
02-26-2020 19:15
I'm having the same issue with my charge 3, I've even played with the brightness settings , cant get it bright enough , is there any salutation to the problem ?
02-27-2020 12:53 - edited 12-28-2023 06:15
Hi there @Mandamay12, welcome to the Community Forums. Thanks for the details provided about the brightness of your Charge 3's screen. Thanks for checking the brightness settings prior to contacting us.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if you have any questions present.
02-27-2020 13:12
02-27-2020 13:12
I can't even see my screen while in the car, forget seeing it outside!
02-28-2020 11:54 - edited 12-28-2023 06:09
Hello there @MLK4647, welcome to the Community Forums.
If your Charge 3's display is getting dimmer, I'd recommend restart it by following the steps below:
Give this a go and let me know the outcome.
02-29-2020 04:55
02-29-2020 04:55
03-02-2020 13:32
03-02-2020 13:32
I think my Fitbit is dead, it will not turn on.
03-08-2020 21:51
03-08-2020 21:51
Me too! Useless outside. Let me know if you find a solution. A friend wears a Garmin and her screen is so easy to read outside. I wish I could afford a new tracker
03-08-2020 21:53
03-08-2020 21:53
Wish they would update it. A friend wears a garmin and her screen is easy to read outside. Wish I could afford a new tracker. My Fitbit Charge 3 is useless outside
03-09-2020 01:04
03-09-2020 01:04
I dont think there is a cure they eventually replaced mine and it's been fine for a few months although touch screen on this does not illuminate when twisting your wrist!!
01-30-2021 10:55
01-30-2021 10:55
I too have this problem and it's so annoying. I have to get out my phone to see the time when I'm wearing my tracker. I sometimes can't see it in a completely dark room! I tried reset and brightness control to no avail. Please help.
