07-18-2019 08:18 - last edited on 11-17-2020 10:55 by MatthewFitbit
I have barely had my Fitbit 3 a month, and there is a black line going down the center of the screen. Anyone know what to do about this?
07-19-2019 04:52
07-19-2019 04:52
A warm welcome to the Community @Za3hwilson.
If your tracker's display is corrupted, I recommend restarting the device by following the instructions provided in the help article: How do I restart my Fitbit device?.
If this process doesn't work, perform a long restart:
Let me know the outcome.
07-19-2019 06:47 - last edited on 07-22-2019 09:09 by AlejandraFitbit
I did both reboot and the shutdown and the line is still there. After I did the long shutdown, the screen was frozen for about 2 minutes, then when it turned back on I has 50% less battery. I started at 65%, now I have 15%.Sent from my Samsung Galaxy smartphone.
I have some thing similar happen to my Fitbit 2 last year. A black line showed up across the screen about 6 months after I bought it, then about 3 months later the Fitbit died. I never got it to work again, which is why I bought a 3. But now it is showing the same line, and I've only had this one about a month. I love the Fitbit, but they dont seem to have a long life.
Moderator edit: content
07-22-2019 09:13
07-22-2019 09:13
Thanks for the update @Za3hwilson.
Since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else.
07-25-2019 12:55
07-25-2019 12:55
I did the reboot and it worked! And then about 12 hours later, the lines appeared again randomly. I’ve been trying to do the reboot again, but it doesn’t seem to be working, lines are still appearing
07-29-2019 09:11
07-29-2019 09:11
It's great to see you here @DyMo555.
I appreciate all the efforts in trying to fix this display issue. Since the instructions you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
07-29-2019 10:16
07-29-2019 10:16
I too have tried this and my Fitbit still has lines through it. It’s gotten worse over the past few weeks. First it was one line and now it is multiple!!!
07-29-2019 10:18
07-31-2019 07:08
07-31-2019 07:08
Completed the restart and line is still there.
08-01-2019 13:54
08-01-2019 13:54
I tried everything in this thread but my screen still has lines through the display. Help?
08-16-2019 17:05
08-16-2019 17:05
Wife's Charge 3 has vertical lines. Problem started shortly after the most recent software update.
Followed the instructions for restarting and then for the alternate reset instructions. No change.
The vertical lines vary in width and are coloured from white through black.
08-17-2019 11:30
08-17-2019 11:30
08-17-2019 13:24
08-17-2019 13:24
Thanks for posting. Armed with your success story, I called Fitbit and a replacement Fitbit is now in the mail.
08-17-2019 15:32
08-17-2019 15:32
08-20-2019 18:55 - last edited on 02-12-2020 16:13 by LiliyaFitbit
Hello AlejandraFitbit,
I want to thank you for that advice, but I have already tried those quick fixes and they did not work. Not sure what to do next, can you give me some advice on how to send it back?
Moderator edit: format
08-20-2019 19:09
08-20-2019 19:09
08-23-2019 20:04
08-23-2019 20:04
I have tried both restarting my Fitbit and performing the long shut down, of which neither have worked. My screen display is not working correctly, pauses between seconds so they jump randomly & my screen touch barely works anymore. Could I please get some help with this? Thank you!
08-26-2019 12:25
08-26-2019 12:25
08-26-2019 14:13
08-26-2019 14:13
What is the approximate turnaround time for a replacement?
08-26-2019 16:07
08-26-2019 16:07
