06-09-2020
23:52
11:20
AlejandraFitbit
06-09-2020
23:52
11:20
AlejandraFitbit
I had the same problem with my original Charge 3, first of all the screen got dimmer and then I had several lines across the center of the display. This has now happened to my replacement pebble, to the extent that I cannot read the date at the top of the screen, with a few more lines halfway down the screen too, impossible to see any display in the sun.
I have tried the various resetting as per instructed last year but it's not rectifying the problem. Is this a common fault with the charge 3 or does it happen with other models. If so I'm not impressed that in the space of 18 months both have had these issues?
10-13-2020
11:22
13:52
10-13-2020
11:22
13:52
It's great to see you around, @Hill75.
I understand how are you feeling and appreciate all the efforts in trying to fix this display issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
Best Answer12-16-2020 00:03
12-16-2020 00:03
Dear I am also facing same problem and bad thing is no service centre in Pune India.
12-17-2020
06:18
13:52
12-17-2020
06:18
13:52
Hi @Djayant, thank you for joining us in this thread and our Fitbit Community. Regarding the screen or display issue that your Charge 3 has experienced, please check out this post, which contains some instructions for this type of issues.
I'll be around if any question arises.
