06-13-2018
04:33
18:54
06-13-2018
04:33
18:54
I’ve tried fully charging my Fitbit, making sure it’s in the proper spot on wrist, right enough, clean, and I keep getting the simplified sleep schedule! I have this weird obsession with checking my sleep so I’m getting real bummed with the never ending boring version. Anyone else have this problem or have a solution??
06-13-2018 07:50
06-13-2018 07:50
my new charge 2 did the deep sleep the first night and has only done the lesser version the next three nights despite charginging position etc.
Best Answer06-13-2018 14:21
06-13-2018 14:21
Buckle up, girl. There are a lot of us with the same problem, if you wanna chime in on the longer thread:
https://community.fitbit.com/t5/Charge-2/Charge-2-not-tracking-sleep-stages/td-p/2266403
I haven’t gotten a detailed sleep graph since the 31st of May, with no fix in sight...I can totally understand your frustration.
06-14-2018 07:14
06-14-2018 07:14
Same issue. App says it isn't getting pulse rate data, but have checked it several times when waking up at night, and pulse data is being recorded.
Best Answer06-14-2018 12:33
06-14-2018 12:33
@gdbtroutfit wrote:Same issue. App says it isn't getting pulse rate data, but have checked it several times when waking up at night, and pulse data is being recorded.
The "can't get consistent heart rate" error message is disingenuous at best.
Sleep Stages is calculated using HRV, not raw BPM. HRV is Heart Rate Variability -- it's a measurement of changes between Heart Beats. The raw heart rate data you see captured all night is not the HRV data. . .
Best Answer06-14-2018 13:26
06-14-2018 13:26
06-14-2018 13:37
06-14-2018 13:37
To clarify, response is intended for fitbit moderator (hopefully) not mjperry51. Sorry if that was not clear.
Best Answer06-14-2018 14:42
06-14-2018 14:42
@gdbtroutfit wrote:To clarify, response is intended for fitbit moderator (hopefully) not mjperry51. Sorry if that was not clear.
I was a little concerned
Best Answer06-14-2018 14:48
06-14-2018 14:48
Best Answer06-14-2018 19:29
06-14-2018 19:29
Again, sorry. But here is another question for the fitbit folks (or anyone else who might know the answer). Is HRV a completely separate measurement or is it derived from BPM using some sort of algorithm? If it is the latter, and BPM is in fact being collected, then it seems the issue is not device-related but some server-side analysis is not happening(?). Did some searching on this question but didn't find a good answer.
Best Answer06-15-2018 04:42
06-15-2018 04:42
@gdbtroutfit wrote:Again, sorry. But here is another question for the fitbit folks (or anyone else who might know the answer). Is HRV a completely separate measurement or is it derived from BPM using some sort of algorithm? If it is the latter, and BPM is in fact being collected, then it seems the issue is not device-related but some server-side analysis is not happening(?). Did some searching on this question but didn't find a good answer.
Simply put, HRV is the variation in Heat Rate that occurs naturally.Your heart doean't beat at a precise rate;the rate can vary from beat to beat.
Here's a good article on HRV -- What Is Heart Rate Variability And What You Can Learn From It
Best Answer06-15-2018 07:22
06-15-2018 07:22
Thanks. Very informative. The article seems to confirm that HRV is calculated from other measurements rather than directly measured. I suspect this is the case with fitbit, but cannot find anything definitive from fitbit on that question. Meanwhile, I received my 4th consecutive night of only basic sleep information while BPM data collection was completely "normal". It would really be great if fitbit would actually respond to these questions as their official guidance is not helpful.
Best Answer06-15-2018 08:20
06-15-2018 08:20
@gdbtroutfit wrote:It would really be great if fitbit would actually respond to these questions as their official guidance is not helpful.
See my post here
Best Answer06-15-2018 08:43
06-15-2018 08:43
Thanks for sharing this. I just got off the phone with Tech Support where I was prompted to do a complete reinstall of software on the device. By asking several questions and interpreting the answers, I'm now pretty sure that the calculations are done server-side using an algorithm and based on Heart Rate data collected by the device (the support agent did confirm that there is a server process involved). I strongly suspect that the weak link may be somewhere in that process. Coming from a long IT background, this makes the most sense to me. I understand that fitbit is in a competitive market and may not want to disclose much about this process, but as a minimum, they should be able to provide customers with direct information about the reliability of that process and whether it is currently "up" or "down" and if "down" when it is expected to be restored.
Best Answer06-15-2018 08:56
06-15-2018 08:56
@gdbtroutfit wrote:Thanks for sharing this. I just got off the phone with Tech Support where I was prompted to do a complete reinstall of software on the device. By asking several questions and interpreting the answers, I'm now pretty sure that the calculations are done server-side using an algorithm and based on Heart Rate data collected by the device (the support agent did confirm that there is a server process involved). I strongly suspect that the weak link may be somewhere in that process. Coming from a long IT background, this makes the most sense to me. I understand that fitbit is in a competitive market and may not want to disclose much about this process, but as a minimum, they should be able to provide customers with direct information about the reliability of that process and whether it is currently "up" or "down" and if "down" when it is expected to be restored.
It's been my view Fitbit has hardware and firmware/software issues.
The hardware works -- sporadically. I believe it doesn't have a wide enough sensor range to accommodate the breadth of physiological situations needed to capture the necessary granular level of data across a widely varying user base. There is either an issue with manufacturing tolerances or quality control. App updates have exacerbated the problems for some users -- not enough beta / pre-release testing.
There are so many places for problems it's hard to see where to start. . . they're clearly in over their head. . .
Best Answer06-15-2018 09:02
06-15-2018 09:02
Best Answer06-18-2018 08:45
06-18-2018 08:45
Hello guys! Thanks for bringing these inconveniences to my attention! Well, I can see that most of you already verified some of the most common factors that could affect your sleep stages. Now, for those who hasn't, I will post them below:
If you have carefully review them, but the issue with the sleep stages persists, I'd like you to tell me if you are getting some type of message on the Fitbit app when checking out your sleep details. If you could post a screenshot, it'll be even better.
Let me know how it goes guys!
Best Answer06-18-2018 11:08
06-18-2018 11:08
The only error message is: "Your tracker couldn't get a consistent heart rate reading while you slept". However, as has been pointed out numerous times, the device is collecting normal heart rate data throughout the night which rules out device and sleep positioning. I have an active case with Fitbit tech support. They are now telling me that they think it is related to my (new) phone, which is rather hard for me to believe since sleep stages were available on that same phone from March 8 until June 12, 2018. But, to eliminate that possibility, I am going to use an older phone to sync tomorrow AM.
Again, my very strong suspicion is that this is some sort of algorithm issue, likely on the server side.
Best Answer06-19-2018 05:56
06-19-2018 05:56
Thanks so much for your response @gdbtroutfit! If that is the response that you are getting, it is because Fitbit estimates your sleep stages using a combination of your movement and heart-rate patterns. While you’re sleeping, your device tracks the beat-to-beat changes in your heart rate, known as heart rate variability (HRV), which fluctuate as you transition between light sleep, deep sleep, and REM sleep stages. If we don’t have enough information on the backend to calculate this, we’ll show you your old sleep pattern which doesn’t require heart rate. It appears as though we didn’t have enough information, and as a result showed your old sleep pattern. We apologize for any inconvenience this may cause. You may want to check the fit of your tracker to make sure we get a good heart rate signal.
But yes, try to sync with your other phone and I want to know how it goes so keep me posted!
Have a nice day!
Best Answer06-19-2018 07:57
06-19-2018 07:57
Thanks you for your reply, however, as I have repeated numerous times, there is not an issue with heart rate data being recorded. It has been recorded every night with no gaps. This can easily be verified by Fitbit by simply checking the data from my device. The loss of sleep stage data occurred suddenly on June 12, and has continued since then. Using a different phone made no difference. With all due respect, Fitbit support on this issue is a bit like groundhog day. Simply repeating the same "troubleshooting tips" over and over again is not going to resolve this issue.
