03-10-2019
19:44
11:22
03-10-2019
19:44
11:22
Disgusted. Charge 3 no longer syncs with iPhone bluetooth; I’ve tried all the suggested “solutions” none worked. Spoke to Fitbit - they know about the issue and asked me to be patient until a fix is developed. P.S. Nice to know Fitbit spent time editing my comments here, yet can’t find us all a solution.
03-23-2019 07:50
03-23-2019 07:50
Welcome on board @twob, @Crazydoglady98, and @Dmintz83! Thanks for your reports with these Android 9.0 syncing difficulties. We’re aware of this ongoing issue and have been working to identify a resolution as quickly as possible.
However, we have some updated troubleshooting suggestions we'd like for you on Android Pie (9.0) to try.
First, turn off Background Restrictions/Limitations: Phone settings > Apps & Notifications > Fitbit app > Background restrictions or Background limits.
Then, disable battery limitations:
Please give the steps above a try to improve syncing with your Fitbit device and Android 9.0 OS. We're still researching and testing out long-term solutions to this ongoing syncing issue. We thank you for your patience while we continue to work on this effort.
Hello @KevinA89! I'm glad to hear our Support Team was able to help.
Hi @Rgmunoz827! The MotoX3 is not yet a supported device with the Fitbit app. Note that the devices on this article have been confirmed as fully compatible with all features of Fitbit devices and the Fitbit app. While a phone or tablet may not be verified as fully compatible, the Fitbit app may still work with your device.
I'd recommend following the troubleshooting steps at: Why won't my Fitbit device sync?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
Hello @Jaelkay! I've seen that you both got in touch with our Support Team. If the issue is still going on after the steps they provided to you, please feel free to reply back to your open case. They will be more than glad to further assist.
Hello guys @Eggbert and @Ringthief! I'm glad to hear you're back on track. Thanks so much for sharing what worked for you. ![]()
Hey @Sandy1949! Did the syncing issue get solved? If you're still having syncing difficulties, please make sure you've followed the recommendations at: Why won't my Fitbit device sync?
Catch you later!
Best Answer03-10-2019 19:57
03-10-2019 19:57
Having same issues!! Will not sync with iPhone X was fine and then stopped working
03-10-2019 22:57
03-10-2019 22:57
Mine as well. It’s been about a week now and nothing works. It’s so annoying. Glad to hear/see I’m not alone right now!
03-11-2019 01:11
03-11-2019 01:11
Having the same problem with mine (this is the 3rd time since December 2018) plus my alarms fail to go off despite being enabled. These issues are sporadic and seem to occur after I’ve charged my Fitbit but don’t happen every time it’s charged. Really not impressed as I had no issues whatsoever with my previous Fitbit (Charge 2) and beginning to wish I hadn’t wasted my money upgrading.
03-11-2019 03:12
03-11-2019 03:12
Exactly the same problem with my Charge 3. I never had any problems with my old Charge 2, and I didn't have any problems with my Charge 3 before. But the last few weeks ... So annoying! Is it too much to ask for a fast solution (yes, I have tried the steps and it hasn't solved anything) since this seems to happen to a lot of people?
03-11-2019 05:59
03-11-2019 05:59
Same here, I wish I haven’t changed to Charge 3! My Charge 2 was working much better than this supposedly “upgraded” version. I’ve tried everything but nothing worked. I’m using iPhone too
03-11-2019 06:41
03-11-2019 06:41
I’ve had the same issue for two months now. Not happy at all. What to do???
03-12-2019 10:56
03-12-2019 10:56
Hello everyone.
I apologize for the delayed response. Thanks or sharing your concerns on the matter.
In this case I'd like to ask some questions about the situations you are experiencing:
Look forward to your replies.
03-12-2019 11:27
03-12-2019 11:27
My issue is syncing. Started with two updates ago on iOS. Using an iPhone 8. Essentially I haven’t been able sync since March 6 the day I did the iOS update to the app.
03-12-2019 11:27
03-12-2019 11:27
I am on an iPhone XR and all was fine until last Thursday, it says it’s connected but will not sync at all. Getting very frustrating
03-12-2019 12:11
03-12-2019 12:11
Same here iOS updated on phone and multiple apps not working. Says connected but won’t sync
03-12-2019 12:13
03-12-2019 12:13
It is with the pairing with the blue tooth as well as the sync . Probably for about a month
03-14-2019 10:47
03-14-2019 10:47
Hello @Lisbar, and @Cdn84. Welcome to the Forums @Katec7.
I apologize for the delay in my response. Thanks for reaching back with that clarification.
My first suggestion would be that you try to follow the steps listed in this help article. While I understand that you all might have already tried some of those steps, please go through all of them in order and let me know how it goes.
03-14-2019 12:09
03-14-2019 12:09
Same here. Worked great for a week. I got the C3 to have better heart-rate record than the Blaze. Mine seems to sync data at times but no longer does notifications. Can't get to the notification menu, etc. Ugh.
Best Answer03-14-2019 19:13
03-14-2019 19:13
Ya nope. Didn’t work. Still not syncing. When is this going to be fixed it’s week 2 now!?!
03-14-2019 19:37
03-14-2019 19:37
I am having the same problems, tried everything, and was told to be patient as well! Also, the steps per hour show up and then disappear but are on my tracker. Never had problems with my old Fitbit and I too am incredibly frustrated.
Best Answer03-14-2019 20:07
03-14-2019 20:07
I have an older iphone 5c. I get that it's and old phone. I received my charge 3 for christmas. It worked fine, I was getting the text and call notifications. After about 10 days. It all stopped. Since then, I have issues sycning on any devise. I have tried my iphone, my windows 10 laptop which is 2 years old and my samsung tablet that is about 2 years old.
03-14-2019 20:12
03-14-2019 20:12
My Fitbit has not synced since Saturday. I finally have steps for today but I'm not getting nothing back from Sunday Monday Tuesday or Wednesday. I never this problem with my charge 2. Extremely frustrated
03-14-2019
21:17
12:36
03-14-2019
21:17
12:36
I have been having trouble with my charge 3 for about 3 weeks. At first it wouldn't sync and updates repeatedly failed, stating it could not find the charge 3. I attempted to re-pair the device by removing it from the app and then pairing again but now the pairing process fails. It gets to the screen where I input the code from the charge 3 to the phone, begins to show pairing ( triangle made of small dots on the charge screen) then never finishes and the charge goes back to the main menu after about a minute and the app just continues "pairing" but not doing anything. I have tried rebooting the device from the settings menu, doing a hard reset by holding the side button until the smile comes on the screen, deleting and re-downloading the app but have made no progress. I bought about 4 of these as Christmas gifts for family this year and now am very embarrassed this issue is happening. Any fixes coming from Fitbit's side?
Update: So after multiple attempts I managed to get it to connect to my phone. Try erasing your user data from the charge 3, do this by going into the setting menu then the "about " section. I have to try this a few times but it did work the 3rd time. Let me and others know if this solved it for you. Apparently all I had to do was complain publicly before the tech decided to cooperate! Good luck. It is now updating and if it fails again after I will update.
03-14-2019 23:21
03-14-2019 23:21
Hi there. I've had several fitbit's from the flex to the Alta and now the charge 3. I've always had problems off and on with syncing but it's always been fixed. It's been 3 days now since Monday and my Fitbit will not sync. I'm very upset as I really use this for my fitness pal and everything. And it also tells me about my sleep that I always follow. There is nothing I've tried everything and I cannot get it to work. I have the Samsung Galaxy 9. Please help.
