11-12-2020
07:45
12:54
11-12-2020
07:45
12:54
Not even two years old and the battery drains and does not hold a charge. When this first occurred, I recharged to 100%, but the battery drained within an hour or two. Now, the battery does not change at all.
11-12-2020
08:04
08:04
11-12-2020
08:04
08:04
@JESQG I hope you are doing fine.
Let me help you with your Charge 3 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help your device charge.
Let me know how it goes.
Best Answer11-12-2020 09:53
11-12-2020 09:53
I followed the self-help instructions at the link that you provided before posting my issue here. And in response to your post, I tried charging again. After an hour, the Fitbit showed the smiley face, but after disconnecting from the charger, the Fitbit vibrated in a pulse pattern for 3 to 4 minutes, and then died again. Its now a brick.
10:23
08:04
11-12-2020
10:23
08:04
@JESQG thank you for the update.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
Keep me posted.
Best Answer11-12-2020 11:53
11-12-2020 11:53
Thank-you. I will wait to hear from the Support team.
