04-16-2022
07:30
10:35
AndreaFitbit
04-16-2022
07:30
10:35
AndreaFitbit
My tracker doesn’t keep time well. The time is good for a short time after syncing instead of continuous sync it syncs when it wants to. This is causing me to be consistently late. I have a charge three. Anyone have a thought on a solution? Thanx
04-16-2022 12:02
04-16-2022 12:02
Thanks for getting back to us and for letting us know that your Charge 3 doesn't give accurate time @Bluebird325.
All day sync feature was removed to save battery life. How often does your tracker sync?
Please check help article: Why won't my Fitbit device sync?
Keep on visiting the forums.
04-25-2022 09:09
04-25-2022 09:09
I am lucky if it syncs 1x day. The time is a little over an hour back now. I try to sync it manually now I get message that one or more of the apps won’t sync. The watch aspect of the fit bit is very important.to me.
Best Answer04-26-2022 09:57
04-26-2022 09:57
Thanks for getting back to us and for letting us know about the message you get when you try to manually sync your Charge 3 @Bluebird325.
I understand how frustrating this could be and could you please send us a screenshot of this message?
04-27-2022 06:27
04-27-2022 06:27
Best Answer04-27-2022 10:59
04-27-2022 10:59
Thanks for getting back to us and for letting us know that the message doesn't appear with uninstalling weather app @Bluebird325.
How did you use to sync your Charge 3 before the time got off? Which apps won't sync when you try manually syncing your device?
Best Answer04-29-2022 04:39
04-29-2022 04:39
Verizon
12:12
Wed, Apr 27
Notification Center
X
Fitbit
Yesterday, 9:53 AM
We were unable to update / install
one or more apps. Please try
again.
Swipe up
to open
O
04-29-2022 13:48
04-29-2022 13:48
I am again receiving the message, I do not know which app or apps are the problem. I can see the clock not keeping accurate time, so I do not know if anything else is accurately reported. Thanks.
I recently rebooted the Fitbit three times and turned it off/ restart. Am excited because it has given me an accurate time for 20 minutes, hopefully it will continue.
Best Answer04-30-2022 10:08
04-30-2022 10:08
Thanks for getting back to us and for your report @Bluebird325. Is your Charge 3 still giving you accurate time?
Best Answer04-30-2022 18:35
04-30-2022 18:35
Yup the correct time is 9:33 my Fitbit thinks it is 6:53.
Best Answer05-01-2022 12:11
05-01-2022 12:11
Hi Bluebird325
My Fitbit charge 3 is not showing the correct time. Do you know how to reset the time please?
Jilliflower
Best Answer05-03-2022 06:52
05-03-2022 06:52
Thanks for getting back to us and for letting us know that the incorrect time situation is still on your Charge 3 @Bluebird325.
I understand how frustrating this could be and the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
@Jilliflower, welcome. Sync your Fitbit device to see the correct time. For more information, see How do Fitbit devices sync their data?
