12-27-2019
11:59
10:29
12-27-2019
11:59
10:29
My Fitbit charge 3 keeps changing and vibrating randomly through the main clock screen and a screen that says “notifications and screen wake”. I can’t use it because of it’s continuous vibration. I’ve had it for a year now and havent one problem with it until now. It is also telling me that my resting HR is 140bpm when it’s usually 65bpm. I have tried restarting it by plugging it into my computer many times but no luck.
Hi there @Stephm88, welcome to the Community Forums. Thanks for the details provided about your Charge 3's behavior and for troubleshooting this issue prior to posting here.
I recommend performing a long restart by doing the following:
If the long restart doesn't work either, please check on the Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Let me know the outcome.
Best AnswerHello!
Now my Fitbit will not keep a charge at all as well as the other problems I mentioned in the last post. I got it charged to 90% and then wore it to bed. When I woke up in the morning it was dead and I had to plug it into the charger to have the smiley face show up and say it was at 0% charged. Normally my Fitbit lasts a week-2 weeks! I hope you can help. Thank you.
Hello there @Stephm88, thanks for getting back and letting me know the outcome of the recommended steps.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to help you.
Best AnswerHello. My charge 3 keeps vibrating also. I’ve restarted it several times. It still syncs. Doesn’t stay long enough to charge though. Please advice on what u should do. Thank you.
