02-26-2019
21:22
11:25
02-26-2019
21:22
11:25
I live in a single level home with just one step to the yard and have justregistered 39 floors ??? How come
02-26-2019 21:26
02-26-2019 21:26
Fitbit detects floors by changes in atmospheric pressure. When very windy or weather changing rapidly, those changes in atmospheric pressure can be interpreted as stairs climbed.
02-26-2019 21:26
02-26-2019 21:26
02-27-2019 01:31
02-27-2019 01:31
Thanks. Would bending to touch your toes then standing upright also register as floors?
02-27-2019 06:06 - edited 02-27-2019 06:07
I would guess not unless you are very tall - it takes 10 foot difference to count as a flight of stairs. But once when I was going up and down stairs to my basement, I found they got counted better if I raised my arms when I got to the top.
I don't remember details, but seems like there is also some mechanism to prevent elevator rides from counting.
But stairs are a stand-alone statistic; it doesn't affect calories or anything else.
02-27-2019 17:21
02-27-2019 17:21
Thanks again. Will see if I can how to discount the elevator find
04-09-2019 09:40 - edited 04-09-2019 09:40
I was getting crazy wild floor counts with my Charge 3. Customer Support replaced it and guess what? The replacement gives me the same crazy wild floor counts! I continued working with Customer Support and they've decided that the crazy wild floor counts are a result of anything except for a defective Charge 3. It couldn't be the Charge 3, so it must be something geographical, opening doors, driving, or riding elevators or escalators, abrupt weather and atmospheric pressure changes or exposure to excess moisture. My thought is that the altimeter is not yet ready for prime time and suggested a software update with an option to disable the altimeter. They offered me a refund if I return my defective replacement Charge 3 and the defective Charge 3 sitting in my drawer. Before I decide what to do, you said something that caught my attention and I wanted to clarify. You said that the floor count is a stand-alone statistic and does not impact calorie count. If this is true, then it makes it much easier to just ignore the crazy floor counts reported. How certain are you that the floor count does not impact the calorie count? Thanks!
04-09-2019 12:24
04-09-2019 12:24
@BobStein3 Verify it for yourself. Look at the fitbit.com dashboard wide daily graph.
You can get reading of calories and stairs in 15 minute intervals, and heart rate in 5 minute intervals. Find a time when you had high stair count but you were not active and your heart rate was low. Look at the calories burned and see if they jump with the stairs count, or seem to match up with your heart rate.
04-12-2019 05:43
04-12-2019 05:43
Im having the same probs...……..would love to know more!!
04-21-2019 11:18
04-21-2019 11:18
I’m having the same problem. Went for a long walk on flat ground today and managed to rack up over 200 floors.
Fitbit, please find a solution as I bought a device so that i didn’t have to guess how much activity I’d done in a day – I could guess better than this!
04-21-2019 11:39
04-21-2019 11:39
04-24-2019 07:34
04-24-2019 07:34
05-15-2019 18:40
05-15-2019 18:40
That's not really a solution. It's just explanation of the problem. I get 60-70 floors a day just working in my shop. I only do 3 floors down in the morning and 3 up in the evening.
05-30-2019 11:23
05-30-2019 11:23
Not a big deal to me but funny. I live in a ranch house, with no stairs. Depending on the exercise I do, or something, I score 2-3 floors a day. Again, no big deal. Could be my aerobics with the high stepping/marching I do.
05-30-2019 17:50
05-30-2019 17:50
05-31-2019 05:58
05-31-2019 05:58
I must challenge your so-called "solution". Telling me the erroneous floor counts reported by the Charge 3 are caused by "the wind" is NOT a solution ... it is an excuse. A solution will result in the Charge 3 reporting accurate data.
Again, I ask you to please give us an option to disable the altimeter until (if ever) Fitbit resolves this issue. I would rather have no floor count data than erroneous data.
06-20-2019 06:42
06-20-2019 06:42
@JohnnyRow The "Accepted Solution" is little more than a possible excuse and does not solve anything. I am still recording an average of 150 floors a week when in reality I do none. Until Fitbit finds a way to provide accurate floor counts, I would prefer to disable the altimeter altogether. Can you unmark this problem as solved? It isn't.
06-20-2019 11:16
06-20-2019 11:16
@BobStein3 Don't blame me for "accepted solution". "Solutions" get so marked by the original poster. Apparently s/he appreciated my explanation. Sometimes "solved" is in the eye of the beholder.
06-20-2019 11:50
06-20-2019 11:50
06-20-2019 13:01 - edited 06-20-2019 13:03
You are free to start another thread about it, though I suspect there are already several, not marked as solved, and I think most, or all, people do realize there are ongoing inaccuracies with floor count, whatever the cause.
06-20-2019 13:58
06-20-2019 13:58
This is not an accepted solution.
This is a useless reply and a non answer.
Sitting on my desk with no wind or weather changes registers 450 floors?
There's cheap trackers from China that do a better job than this
