12-15-2020
03:06
05:30
AlvaroFitbit
12-15-2020
03:06
05:30
AlvaroFitbit
Hi
I have an issue with my charge 3, brought in june now is missing pixls on it. I'm looking for the serial number but it isnt on the box as the box is ripped. Is there any other way to get my serial number
Thanks
12-15-2020
05:53
10:15
12-15-2020
05:53
10:15
@Moomin21 Welcome to the Fitbit Community!
Let me help you with this. Is there any reason you need the Serial number. As you mentioned it shows on the box so if you don't see it there due to damage there isn't much that can be done. Regarding the tracker you don't mention any troubleshoots so I suggest you restart it by doing the following:
Let me know how it goes.
Best AnswerHi
Thank you for your help, I have restarted my fitbit as you suggested but the missing pixls line, is still there. The reason for asking about the serial number was as I have only had this Fitbit since june this year it should still be under warranty but without a serial number doing something about it will prove difficult
Thanks
08:23
10:15
12-16-2020
08:23
10:15
@Moomin21 thank you for the reply.
Since the issue persists I have created a ticket so our Support team can further assist you via email. They are able to review your accounts and tracker's information in details so hopefully they will be able to assist you.
I have been having the same issue for a few weeks. Started with a black screen and no data so I just did my workout anyway then noticed it on 30 mins later but with missing pixels. It’s like striations through the display and been that way for a few weeks. I restarted as you suggested above with no resolution.
Please advise. Thank you!
06:15
10:15
12-17-2020
06:15
10:15
Hi @Seattlebiker, thank you for joining us in this thread and our Fitbit Community. Regarding the screen issues that your Charge 3 has experienced, please check out this post, which provides some instructions for this type of issues.
I'll be around if any question arises.
Best AnswerHello, I'm also having an issue with my charge 3 where there are many missing pixles suddenly and getting worse by the day. The display is also very dim and impossible to see when outside.
04:21
10:15
04-24-2021
04:21
10:15
@Winston99 Thank you for participating in our Fitbit forums. Since you mentioned that the screen of your Charge 3 is dim and has missing pixels, please restart it as described in this help article.
After this, monitor your tracker and see if the issue gets fixed.
Hope this helps.
Best AnswerOf course I’ve read through the entire thread and tried all the non-fixes before adding my comments. It’s a faulty device and needs replacing. Same as the thousands of others. Could you please escalate my case. Thank you.
04-26-2021
04:04
10:15
04-26-2021
04:04
10:15
@Winston99 Thank you for getting back and letting me know that you had already tried the steps. Since the issue persists, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected and our Support team will be happy to follow up and assist you accordingly.
See you around.
