11-08-2020
09:48
12:57
11-08-2020
09:48
12:57
Fitbit ran out of charge and now will not charge, ive purchased a new charger and this is still not working. Has anyone came across the same issue?
11-09-2020
03:47
10:18
11-09-2020
03:47
10:18
@Amymc95 It's great to see you in the Community!
Let me help you with your Charge 3 not charging and thank you for purchasing a new charging cable. Not sure if this is a screen or charging issue so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your device charge.
Let me know how it goes.
Best Answer11-09-2020 10:23
11-09-2020 10:23
08:39
10:18
11-10-2020
08:39
10:18
@Amymc95 thank you for the reply.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
Keep me posted.
