10-29-2018
09:46
15:03
10-29-2018
09:46
15:03
My Fitbit is less than a month old & the time, etc stopped showing when I turn my wrist towards me. How do I get this to work again? Now I have to tap the side of the watch to get it to show me anything.
10-31-2018 07:47
10-31-2018 07:47
It's great to see you around @Horseylady.
If the quick view option isn't working in your Charge 3, I recommend restarting it by doing the following:
I hope this helps, let me know the outcome.
11-07-2018 06:32 - edited 11-07-2018 06:34
I tried to restart and the quick view is still not working. Any advice? I did the update yesterday and I have been having a few problems since then.
11-07-2018 06:46
11-07-2018 06:46
That worked for me! My charge 3 would only vibrate when I tried to access the quick menu. It's working fine now after restart.
Thank you!
11-07-2018 08:21 - edited 11-07-2018 08:21
I figured it out! Hold the haptic or home button for a couple of seconds until the wake icon shows and turn it on. For some reason mine had turned off.
12-08-2018 06:47
12-08-2018 06:47
Worked for me. Thanks for the easy solution.
12-09-2018
04:33
07:05
12-09-2018
04:33
07:05
Hey guys, hope you are doing fine.
I appreciate the information provided, it's great to know that your trackers are now working properly. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
12-16-2018 17:16
12-16-2018 17:16
I had this same problem, and turned out I had turned quick view off.
The location of this setting is not user friendly at all. The tracker as a dedicated “Settings” app, and more tracker settings can be accessed from the Fitbit app. But “Screen Wake” is obscured behind another “settings” pane that only appears when you hold the side button down.
How are users supposed to figure this out? Why isn’t this setting just with the rest of them under “Settings”?
12-17-2018
05:23
07:04
12-17-2018
05:23
07:04
Great to see you here @akowalz.
I appreciate the feedback provided about the quick view feature and think that your idea is great. I took the liberty and searched for a request like this but didn't find any. Feel free to visit our feature suggestions board and share this.
Let me know if you need anything else!
12-18-2018 08:12
12-18-2018 08:12
I've submitted a feature suggestion to move the "Screen Wake" setting to the Settings app on the tracker.
If you also had difficult finding this setting, considering voting/commenting on that suggestion.
01-12-2019 10:23
01-12-2019 10:23
Can not get screen back to clock. Tried changing and holding button for 8 secs. Nothing. Ready to return. So frustrating
01-13-2019
03:16
07:03
01-13-2019
03:16
07:03
Hey @Jersey_jersey, welcome to the Community.
I appreciate all the efforts in trying to fix this stuck issue by yourself. Please confirm you followed these steps in order to restart your tracker:
Let me know the outcome.
02-25-2019 07:39
02-25-2019 07:39
I am so frustrated that this keeps happening. I have done all of the steps you suggested and It is not correcting the problem of making quick display turn on/off. I am very close to leaving fitbit altogether due to this constant issue!
02-25-2019 07:41
02-25-2019 07:41
Thank you! I can’t believe it’s that hard to find. Ridiculous. But you helped me. Silly someone from FitBit didn’t even know that. Yikes!
02-25-2019 12:01
02-25-2019 12:01
thank you !!! IT WORKED right away.... !!!
03-14-2019 12:08
03-14-2019 12:08
Yes!! That actually worked! 😁😁
03-15-2019
04:19
11:39
03-15-2019
04:19
11:39
A warm welcome to the Community @Dessi.
I am glad to hear that the instructions provided worked and that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
07-17-2019 12:58
07-17-2019 12:58
Hi all,
I could use some help getting with Quick View to work. Charge 3, Version 28.200001.63.5. I have re-booted, updated software, made sure Screen Wake was on...
What else can I do?
Many thanks!
08-09-2019 03:43
08-09-2019 03:43
Ha! This was my problem... wow, what an un-inuitive design for such a common and basic feature! Just switched from a Charge 2 to a Charge 3, so I spent lots of time trying to locate quickview on the app (not the device!)... my old eyes can barely READ the tiny print on the screen to even figure out what it said!
01-10-2020 09:00
01-10-2020 09:00
worked for me, thank you so much!!!!
