03-06-2019
10:10
11:22
03-06-2019
10:10
11:22
My Fitbit Charge 3 died. Charged it but still not responsive. Red light at back of watch.
03-07-2019 05:02
03-07-2019 05:02
A warm welcome to the Community @SunsetRunner.
I am sorry to hear about the issue you are experiencing with your tracker. Have you tried to restart your device? If you haven't, I recommend restarting it by following the instructions provide in the help article How do I restart my Fitbit device?.
Let me know the outcome.
03-07-2019 05:22
03-07-2019 05:22
03-08-2019 03:11
03-08-2019 03:11
Thanks for the update @SunsetRunner.
If the restart process doesn't work, I recommend changing your clock face by following the instructions provide in the help article How do I change the clock face on my Fitbit device?.
Keep me posted.
03-10-2019 03:05
03-10-2019 03:05
04-08-2019 02:31
04-08-2019 02:31
Hi,
was this issue resolved?
I am having similar issues with my charge 3 and have restarted it a few times.
Thanks
04-10-2019 01:03
04-10-2019 01:03
06-07-2019 08:15
06-07-2019 08:15
I am also having the same issue. I've been told I'd be contacted and am still waiting to hear from Fitbit via email. My Charge 3 is only 4 1/2 months old and suddenly went bezerk
06-07-2019 09:41
06-07-2019 09:41
06-25-2019 11:58
06-25-2019 11:58
I am also having the same problem. Not getting anywhere with customer support! Only had my charge 3 for 10 months and it has gave me nothing but bother.
06-25-2019 12:18
06-25-2019 12:18
06-25-2019 15:56
06-25-2019 15:56
I have the same issue. The red light doesn’t go away after rebooting the device. I even disconnected the device from the app and set up as a new device, still no luck.
If I wear the Fitbit, it is showing unusually high heart rate and active minutes.
06-25-2019 21:54
06-25-2019 21:54
07-03-2019 12:59
07-03-2019 12:59
I had the same issue as well. Red light on which drains the battery very fast and incorrect heart rate readings. I chatted with Fitbit support and they are sending me a replacement. The support person said that there was nothing I could do to fix it.
07-03-2019 13:25
07-03-2019 13:25
Thanks Jeff.
i called them multiple times and also sent them an email. They keep telling me to reboot the device.
07-04-2019 08:50
07-04-2019 08:50
07-09-2019 22:33
07-09-2019 22:33
Just sent an email to customer support, experienced red light issue tonight. I felt a burning sensation on my wrist, and noticed the red light flickering. I removed the device and notice the screen eventually went blank. Have some safety concerns, not sure if it is the battery. Do not want the device to explode, or catch fire. I cannot turn it off. I am putting it in a glass case for now, while awaiting a response from customer support.
07-10-2019 05:13
07-10-2019 05:13
The phone call with the customer support didn’t help, but the chat did. The person asked me to return the device as it is still under warranty. They will send me a new device in a week.
07-10-2019 07:50
07-10-2019 07:50
Hey guys, thanks for your participation in the Community.
@Buffalo-Soldier, it's great to hear that you sent an email to our support team regarding the issue you are experience with your Charge 3. Since you have already contacted them, I recommend keeping an eye on your inbox for further assistance. I know they will be glad to help you out and provide you a solution.
In the meantime, I suggest taking off the device and check our wear and care page.
@Aparna_N, those are great news. I am glad to hear that you will be receiving a replacement. At the moment of receiving it, you can follow the instructions provided in the help article: How do I set up my Fitbit device? to set it up.
I will see you around.
08-01-2019 06:47
08-01-2019 06:47
My Charge 3 died on my yesterday. Just a red light showing with my screen blank. I've tried to restart but it doesn't work and it's useless to change clock faces since the app doesn't want to connect and synch at all. I have emailed customer support and am waiting for their reply.
