02-28-2019
09:13
11:22
02-28-2019
09:13
11:22
I'm having the same problem described here https://community.fitbit.com/t5/Charge-3/Charge-3-is-showing-white-vertical-lines/m-p/3305047#M44483
It happened after charging after running out of battery.
What should I do? My screen works but it has vertical lines all over the place.
03-01-2019 04:12 - edited 03-01-2019 04:14
Welcome on board @HugoCSousa, it's nice to see you here! Thanks for describing the problem you're having with your Charge 3.
If the display has vertical lines, I'd recommend restarting your Charge 3 by following these steps:
Let me know the outcome!
Best Answer03-07-2019 11:42
03-07-2019 11:42
Hi,
The restart didn't solve the problem.
What should I do next?
Thanks
03-08-2019 09:18
03-08-2019 09:18
Thanks for trying the restart recommended @HugoCSousa! I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
Best Answer03-11-2019 11:43
03-11-2019 11:43
Hi,
I'm still waiting for contact.
Thanks
03-12-2019 10:15 - edited 03-12-2019 10:15
Hi there @HugoCSousa! I've seen that you got a reply from our support team after posting here. ![]()
If there's anything else I may do to assist, let me know.
Best Answer05-15-2019 16:18
05-15-2019 16:18
I am having the screen issue with the lines that started yesterday when I charged my Charge 3. I tried the restart and reboot twice and neither is fixing the problem. My Fitbit is 6 months old and I love it. I’ve had a Fitbit since the first one came out years ago.
What other options are there to fix this screen issue?
Thanks,
Cindy
05-15-2019 19:55
05-15-2019 19:55
I've been having the same problem with my Fitbit. Just started this morning out of no where and have tried restarting it and changing the face but hasn't worked. Any other tips or tricks
05-16-2019 09:35 - edited 05-16-2019 09:37
Welcome to the Community Forums @Cindyfit4life and @Doucette94! Thanks for following the tips and recommendations provided in order to solve the issue with the white lines on your Charge 3 devices.
Since the steps recommended did not work, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's any questions present.
05-16-2019 09:42
05-16-2019 09:42
I have the exact same issue - I've tried holding the power but after the smiling face shows - I still have the same issue. I've also noticed the screen isn't responding the same to swipes 😞
Please can you pass on to customer support?
Thanks
Matt
05-16-2019 10:05
05-16-2019 10:05
Welcome to the Community Forums @MatthewGardner! I'll be more than glad to help you. ![]()
Thanks for already restarting your Charge 3 in order to solve the lines on the screen. As per the description of your post, it seems that your device is still syncing, so I'd suggest changing the clock face to a different one to see if this brings the display back.
No worries if you cannot swipe the screens, this process is done through the Fitbit app.
Give this a go and let me know the outcome.
Best Answer05-16-2019 10:14
05-16-2019 10:14
05-16-2019 15:46
05-16-2019 15:46
05-17-2019 10:15
05-17-2019 10:15
What else can we try?
05-17-2019 14:39
05-17-2019 14:39
I have the same problem. Bought my charge 3 direct from Fitbit the day they were released. I had it approx 2 months and had lines appear across the screen. Fitbit were fantastic and replaced it without quibble in December 2018. Last week I developed the same problem but this time with vertical lines not horizontal. Again Fitbit sent me a replacement without question. The replacement came today and has vertical lines all over it before I've even set it up!!!!!!!
This is getting ridiculous. I had my Charge 2 for two years without any issue whatsoever. What is wrong with the 3's????? What use is sending me a replacement that is already faulty 😞
05-17-2019 14:42
05-17-2019 14:42
This is getting ridiculous. I had my Charge 2 for two years without any issue whatsoever. What is wrong with the 3's? What use is sending me a replacement that is already faulty
05-23-2019 11:03
05-23-2019 11:03
@MarreFitbit I've tried restarting, changing the clock face - what's else can I try? I bought the Fitbit 6 months ago 😞
05-23-2019 11:52
05-23-2019 11:52
Hello, My charge 3 is doing the same thing. White vertical lines. I tried restarting it but it hasn't changed anything. Is there anything else I could try?
06-09-2019 14:16
06-09-2019 14:16
I have grey-ish vertical stripes. I don't know if they are sort of grey or sort of white but I have them and resetting the fitbit didn't do anything. I tried holding down for fifteen seconds and then it shows the smiley and restarts but the screen stays the same.
I didn't put any water on it. It happened randomly while charging.
I can't replace it because it was a birthday present and I can't afford a new one so any other solutions that would be helpful and would fix it?
06-09-2019 14:54
06-09-2019 14:54
