11-03-2020
13:28
13:00
11-03-2020
13:28
13:00
Like many others, my screen is blank. The Charge 3 is syncing with the app on my phone. It will vibrate at appropriate times. When I do a resent with the power cord, the smiley face shows briefly.
Looking at other threads, I have installed a new clock face. That seemed to work from the app and the wristband vibrated when the loading was done. But screen still blank. I did another reset, still nothing.
I purchased this 23 January 2019.
Thank you, jj
11-03-2020 13:42
11-03-2020 13:42
I'll also add..... its been like this about 3 weeks. I've done multiple reboots. Acting on an idea from an on-line group, I also let the battery completely drain. then recharged it- still blank. As I said previously, I've also sent a new clockface to it, which I believe was successful- but I can't see it!
Thx, jj
Best Answer11-03-2020 13:52
11-03-2020 13:52
Call and get a warranty claim going as you are still under a year
Mine did this and when I called to figure out a course of action I also mentioned that in the past I had just used the darkness/lightness adjustment option in the app, and that the removal of that feature from the app was probably a bad call on their end.
11-03-2020 13:58
11-03-2020 13:58
Thank you AutL78, How do I find the number to call?
09:26
04:16
11-04-2020
09:26
04:16
@jjpdx @AutL78 I hope you are doing fine.
Let me help you with your Charge 3 screen not working as it should and thank you for troubleshooting this issue. I have created a ticket so our Support team can further assist you via email. Also you can check our Support's contact channels here.
@AutL78 thank you for your help in this thread.
Let me know how it goes.
