01-04-2021
15:11
03:11
AlvaroFitbit
01-04-2021
15:11
03:11
AlvaroFitbit
Wording on Charge 3 screen is very dim. Is there a setting that can be adjusted?
01-05-2021 03:13
01-05-2021 03:13
@Shag I hope you are doing fine.
Let me help you with this. Make sure that your tracker isn't in the Do not disturb mode or Sleep mode as this can dim the screen. Check the tracker's settings for brightness too. Finally if these aren't factors then you can try restarting your tracker by doing the following:
Let me know how it goes.
