07-01-2019
01:07
10:58
07-01-2019
01:07
10:58
Please advise possible reasons why my Fitbit 3 has a very dim display
07-02-2019 04:22 - edited 10-11-2024 06:29
Welcome to the Community Forums @SunsetRunner!
On the Charge 3, swipe to the left until you see the "Settings". Tap on "Settings" and "Brightness Settings", should be your first option. Tap on "Brightness" to cycle through the options.
You only have three options for brightness: Dim, Auto, and Normal. I keep mine on Normal, as I like a bright screen.
If your tracker brightness is still too dim after switching from the options, you can restart it by following the instructions provided in the help article: How do I restart my Fitbit device?
Give this a go and let me know the outcome. ![]()
07-05-2019 05:20
07-05-2019 05:20
07-05-2019 06:20 - edited 10-11-2024 06:28
Hello there @SunsetRunner, thanks for coming back and following the recommendations I've suggested.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you with. ![]()
Best Answer03-18-2020 09:15
03-18-2020 09:15
What did happen with this case? I've the same problem and don't know how to fix it. The brightness in NORMAL is so dim that can only be read with in darkness, but not in any lit place (and definitively not outside). Please advise... Thanks!!
03-18-2020 18:05
03-18-2020 18:05
I have the same problem. Only have 2 settings, auto and normal. Set at normal it is not bright enough to read in a lighted room or outdoors. Set to auto, all you can barely see is the "Fitbit" at the bottom of the screen. And this is in a completely dark room. I have restarted several times and long restart, has not done anything. Also does not vibrate anymore.
03-19-2020 08:07
03-19-2020 08:07
Thanks for getting in touch. I couldn't solve the problem, I think it is internal issue. I contacted Fitbit in UK and I think they would have replaced it, if I had bought it form a registered agent in UK. But as I bought it in Dubai they would not change it. It eventually 6 months became unusable. Its now lying in the cupboard!
regards
07-06-2020 20:43
07-06-2020 20:43
Thank you to whoever posted the directions in settings. After 3 months of standing in the closet to read the info or logging into Fitbit your suggestion solved the problem.
Thanks again
11-11-2020 22:26
11-11-2020 22:26
But when I take off frome my wrist, sometimes Charge 3 can bright as I can read under the sun. Don't know why but it's dim even in Auto/Normal mode.
11-11-2020 22:27
11-11-2020 22:27
it's dim and hardly to see under normal condition; see nothing under sunlight/ outside
11-15-2020 21:04
11-15-2020 21:04
Is there a bright setting that can be installed? Normal is way too dim for outside use. I've restarted, hard reset, etc. This seems to be a new issue. Wasn't there a bright setting before?
11-16-2020 00:52
11-16-2020 00:52
Hi there,
My Charge 3 used to have a good brightness to the screen, but after the last firmware update, the brightness of the screen is way too dim, but since I don't get out much after recent global events, it was less of an issue until now. With summer approaching in my country, I recently went out into the sunlight and while outside found that I couldn't view anything on my Charge 3 anymore.
I've tried all the brightness settings and find that when I choose the Dim option, I can't see anything on the screen at all, and have to guess at what I'm pressing next. The Normal setting sets it to a dimness that I would expect to see with the Dim option, and the Auto option never goes brighter than the Normal option. I also restarted the Charge 3, but to no avail.
When I play around with some of these settings, at times, the screen does go bright again, as it used to be, but it takes less than a second to revert to the Normal setting, so I'm quite sure this isn't a device problem, but a programming problem on the device which came in after the last firmware update.
If it is in any way possible for me to go back to the older firmware version, please let me know. I'd rather go back to a previous firmware version on my Charge 3, so that I don't experience this issue anymore.
11-16-2020 06:41
11-16-2020 06:41
what if it is so dim that I can't see to get to the settings ? I thought there was a way to do setting from the app on my phone but I can't find it anywhere ... how do I change the brightness if I can't see it because it's to dim? 😞
12-04-2020 06:58
12-04-2020 06:58
Agree - mine has been horrible the last few weeks. Only time it's easily read is at night in the dark. Dim isn't readable at all and Normal & Auto are the same.
07-11-2021 06:12
07-11-2021 06:12
I do not believe this post. Nobody has confirmed that setting to NORMAL has helped, in fact, most have said that there is no difference.
07-12-2021
07:39
06:28
07-12-2021
07:39
06:28
Hello everyone. @ElwyAli Welcome to the community forums.
I'm sorry for any inconvenience and thank you for taking the time to provide your feedback. Sometimes changing the brightness setting to normal has helped, but I also recommend checking this thread for additional tips and suggestions.
If those tips still don't work, I recommend contacting our Support Team for further assistance. Note that you can contact them through chat or over the phone, but phone wait times have been longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
07-12-2021 17:57
07-12-2021 17:57
Your instructions to increase Brightness were so clear, I was able to select Normal even though my screen was so dim I couldn't read it. Thanks!
07-15-2021
08:02
06:09
07-15-2021
08:02
06:09
Hello @Dewey730. Welcome to the community forums!
Thank you very much for the information and for following the suggested tips in this thread. I'm glad to hear that you were able to change the brightness setting.
On a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
See you around.
08-29-2022 15:19
08-29-2022 15:19
Useless ! we cannot access the page anymore! Why ?
09-01-2022
11:00
11:25
09-01-2022
11:00
11:25
Thanks for getting back to our community @LionBelfort. I'm sorry to hear about your experience.
Could you please let me know which page you don't have access to?
Keep on visiting the forums.
