12-26-2018
10:37
14:31
12-26-2018
10:37
14:31
This Fitbit Charge 3 that I have is not responding. I was wearing it and I went to look at the time, and the screen was just black. The screen is completely black, but I know it's on because there is a flashing green light at the bottom and when I plug it in to charge it vibrates. Everything is on, but the screen is completely black. I've tried pressing and holding the button on the side while it's plugged in, but that doesn't work either. Any advice as to what I should do?
02-07-2020
15:27
08:50
02-07-2020
15:27
08:50
Hi @LorryLu92. Welcome on board. @sunshine122 and @Obi-User, thanks for getting back. I'm sorry for the delayed response.
@LorryLu92, thanks for your efforts while troubleshooting your tracker, as well for sharing the steps that worked for you. I'm sure others will find them very helpful!
@sunshine122, I'm sorry that your Charge 3 is now not able to be set up to your Fitbit account. I've checked with our Support team and apparently they already took your case under their wings. I'd recommend to keep working with them so you can receive more details about their resolution.
@Obi-User, thanks for taking the time to share your feedback and I'm sorry that you're having this experience with your Charge 3 despite the troubleshooting steps tried. Our team reviews every feedback posted in the forums to improve our products, services and overall environment, so be sure that your comments won't go unnoticed. If you decide to give it another chance, please let me know so I can work with you.
15:32
13:39
LizzyFitbit
02-07-2020
15:32
13:39
LizzyFitbit
Fitbit said mine was not working and I have purchased an inspire. I thought I had the inspire HR abut it was my mistake on ordering
Moderator edit: removed personal information
13:46
08:49
02-10-2020
13:46
08:49
Hi @sunshine122. Thanks for getting back.
I'm sorry for the delay and I appreciate you for clarifying that you got the Inspire. Let me share that Fitbit provides refunds to any order purchased from our Fitbit store that is within 45 days as described here. Please confirm if this applies to you as well if you still wish to have the Inspire HR, that way I can get in touch with our Support team and request a case on your behalf to receive assistance with this process.
If your Inspire was purchased from another retailer, I'd recommend to get in touch with them so they can provide you with more details about the refund policy.
Best AnswerThe charge 3 screen not responding is not working for me. I have done this multiple times in the last 24 hours and still have a blank screen. In addition, the clock is now not working. I also cannot get the fitbit to sync to the app on my iphone, so nothing is working even though the fitbit 3 is charged and the light is appearing on the underside. Help
02-18-2020
10:57
08:49
02-18-2020
10:57
08:49
Hi @Crazy123. Welcome to the community forums.
I'm sorry for the delayed response and thanks for troubleshooting your Charge 3 to get the screen working correctly. Since your post didn't mention, may I know if you've performed a regular restart on your tracker, as well the long restart described here? If not, please give it a try as these steps have worked for other users.
I'll be around, keep me posted.
Best Answer05-07-2020 13:39 - last edited on 06-24-2020 19:56 by LiliyaFitbit
I replaced mine. Stopped working period
05-09-2020 06:40 - last edited on 06-24-2020 19:55 by LiliyaFitbit
They replaced mine
Best AnswerGreat message Obi-User. I'm not having the same problem but I share your frustration. I've had problems syncing my Charge 3 since I've owned it. 6 days ago it stopped syncing and the app can't find the tracker. I am not tech illiterate and I've tried everything from the Windows 10 side and the Fitbit app too. Very frustrating. I like having the watch when it works. I like to hike a lot and walk my golf rounds. It's good to see how many miles and floors I've walked. I'm going to look into Galaxy 1st as an alternative.
Best Answer05-27-2020 13:18 - last edited on 06-24-2020 19:55 by LiliyaFitbit
Mine just dies too.
Best AnswerI have the app on my Windows 10 PC. I've tried all of the usual troubleshooting: toggling bluetooth, restart app, restart PC, remove fitbit base station from bluetooth, reconnect and other combinations. My PC can see the dongle but not the charge 3. I think that the Charge 3 just doesn't play well with Windows 10 OS.
Best AnswerHi Lizzy. My Charge 3 stopped syncing again 2 days ago: Windows 10 PC. I also tried Classic Mode force sync with dongle. The app says that sync was successful in this mode but when I go to the dashboard the C 3 icon says 'tracker not found'.
When I remove the fitbit station from bluetooth, remove the dongle the C 3 won't pair with bluetooth. In summary, I'm trying classic mode with dongle, bluetooth pairing without dongle, bluetooth pairing with dongle but none of the above are working.
Best Answer05-27-2020 17:37 - last edited on 06-24-2020 19:55 by LiliyaFitbit
Talk to,Fitbit. Maybe needs replacement
Best AnswerI bought a Charger 3 recently but my iPhone thinks it is my old fitbit. It will not sync, etc.etc. and I have clipped rhe charging cable on, plugged it in but it just says over and over "fitbit.com/setup".
Best Answer06-02-2020 08:03 - last edited on 06-24-2020 19:54 by LiliyaFitbit
I contacted Fitbit via a service chat. I detailed all my efforts to sync my
Charge 3. They said this is a Microsoft issue so they had me submit the
details through Microsoft's Feedback Hub. Basicall I am to wait until
Microsoft provides a patch.
I don't think this is true. My Charge 3 won't sync with Android an y longer
as of 2 days ago. My guess is that my Charge 3 has simply failed. It can't
pair to any device using Bluetooth. I've owned my Charge 3 for about 1.6
years. Disappointing for sure.
