01-13-2020 07:05 - last edited on 09-24-2020 19:06 by
The watch face of my Charge 3 isn't working properly. When I tap it it lights up and displays the time, but I'm not able to scroll down or to the right. I've tried charging it and resyncing it through the app but am not sure what else to try. Is there a better way to troubleshoot?
01-14-2020 06:22 - edited 10-08-2024 08:16
Hi there @Nicola1430, welcome on board. I am sorry to hear that you are going through this situation. I appreciate your feedback for the Fitbit Charge 3.
Please note that our main purpose is to avoid negative experiences to our customers, we're always willing to help and provide troubleshooting steps. Then, if the tracker is deemed defective we review eligibility using the one year warranty option.
Additionally, our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they are helping you with this.
Let me know if you have any questions present.
01-14-2020 05:47 - edited 10-08-2024 08:17
Hi there @Enels2, welcome to the Community Forums. Thanks for the details provided and for taking the time to restart and charge your Charge 3 to fix the screen prior to posting here.
Since the steps you tried didn't work, I'd recommend performing a long restart by following the steps below:
If the long restart doesn't work either, please check in your Fitbit app if your Charge 3 is still syncing. If so,change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Give this a go and let me know the outcome.
01-14-2020 05:57
01-14-2020 05:57
