01-12-2020 06:46 - last edited on 09-24-2020 19:06 by
I have done everything that has been said to do to no avail. My Charge 3 still tracks steps but I had to reset to factory settings to get the correct date and time. When I try to set up the device with the Fitbit app it finds the tracker but does not connect. I have had this Charge 3 for a little over a year so no warranty coverage. HELP!!
01-13-2020
05:33
07:45
01-13-2020
05:33
07:45
It's great to see you around, @primrosesm.
Thanks for troubleshooting this syncing issue. If now you are having setup issues, I recommend taking a look at the help article: Why can't I set up my Fitbit device? and follow the instructions provided there.
Let me know how it goes. 🙂
Best Answer01-16-2020 03:53
01-16-2020 03:53
Absolutely nothing worked. I ended up buying a different Fitbit. So disappointed in the charge 3. It lasted only a year.
12:41
07:45
01-17-2020
12:41
07:45
Thanks for the update, @primrosesm.
I am sorry to hear about your disappointment. It's great to hear that you bought a different unit that it working properly. If there is anything else we can help you with, do not hesitate to post it.
I will see you around.
