05-19-2020
03:08
08:53
05-19-2020
03:08
08:53
I am having trouble syncing my charge 3 since the new update on the app. When I try to sync it just says device not found. I followed all the steps in the help article and in the end had to delete it off my account and set it up on the laptop as my phone couldn’t connect to it.
i can no longer connect it to my laptop either. This is very frustrating!
05-19-2020 03:57
05-19-2020 03:57
Likewise! I can't connect my Charge 3 to my iPhone since Friday when my phone installed its update. Have tried rebooting Charge 3, turning phone and bluetooth on/off, and cannot get the two to sync.
05-19-2020 04:03
05-19-2020 04:03
Same here, frustrating! My device is good but since nothing gets on app, it affects my ww app results too.
hope they are working on this
05-19-2020 06:38
05-19-2020 06:38
Same thing happened to me and appears to have started last Friday, too. None of the solutions suggested on the Help pages have worked.
05-19-2020 06:44
05-19-2020 06:44
Everyone seems to be mentioning problems with syncing through their phones, with no mention of what platform the phone is on, or at least there phone model.
Best Answer05-19-2020 06:51
05-19-2020 06:51
Same issue after all attempted remedies. Iphone and Ipad ...
05-19-2020 07:08
05-19-2020 07:08
I’m having the same issues. My iPhone and my iPad do not recognize my device.
05-19-2020 08:30
05-19-2020 08:30
My Charge 3 stopped syncing with my phone on or about May 14 after charging my device. I tried all the recommendations from FitBit regarding quitting the App, turning off Bluetooth etc....nothing worked. I finally went into my Bluetooth on my phone and selected "forget this device". Did that, then reloaded and reconnected using Fit Bit app on my phone and all returned to normal.
05-19-2020 08:35
05-19-2020 08:35
I spoke to Fitbit customer care. Once I went into my bluetooth settings, removed my charge 3 by selecting "forget this device", then reinstalling it, I was able to get my decide to sync
05-19-2020 10:25
05-19-2020 10:25
Thank you for sharing the advice you received from Cudtomer Care.
My Charge 3 finally connected to my ipad air 2 bluetooth. My Charge 3 is not showing as connected on iphone xr bluetooth. Howevever the fitbit app is showing the same info as my ipad.
I am relieved.
05-19-2020 12:51
05-19-2020 12:51
Awesome, thank you. I can finally sync again!
Best Answer05-19-2020 12:53
05-19-2020 12:53
Thankyou for letting us know. I’m really glad I can sync again 😅
Best Answer05-19-2020 13:01
05-19-2020 13:01
Not synching either, I have tried all the suggestions from fitbit and have ended up being told that fitbit does not support my phone (Huawei P20) I am not impressed as I have only recently purchased a fitbit. It is not much use to me and do not intend buying a new phone!
Best Answer05-19-2020 13:20
05-19-2020 13:20
That worked for me. Thanks so much for posting!
Best Answer05-19-2020 22:17
05-19-2020 22:17
I am having this problem too.
I have turned off and on
deleted and reinstalled the app but still says no device found
05-19-2020 22:36
05-19-2020 22:36
Took your advice and so far seems close to normal except if go back a few days , hopefully it works itself out , thanks
Best Answer05-19-2020 23:11
05-19-2020 23:11
Thank You!
Best Answer05-20-2020 10:51
05-20-2020 10:51
I’m not sure where you deleted your device.I deleted my devices from Bluetooth and I also still don’t see my device listed but it did sync.
i did not delete the app
Best Answer05-20-2020 11:10
05-20-2020 11:10
Best Answer05-20-2020 11:16
05-20-2020 11:16
I’m using an iPhone 5SE, which should not be a problem. I recommend FitBit update their new platform to the previous platform.
What has happened here is simply stupid.
