Charge 3 stopped vibrating
I tried restarting my charge 3 came up with smile but still not vibrating some one help!!!
9 REPLIES 9
Same! Got a new band because mine broke and since replaced it no vibrations at all . Have reset , hard reset and checked all settings. Still no vibration ugh
@Tictok123 @Xrayrox I hope you are doing fine.
Let me help you with this and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Alvaro | Community Moderator
Thank you . I kept messing around with setting on the actual fitbit . Since I changed the broken band I figured I pushed something accidentally. I found sleep was set from 10 pm to 6 am and I unchecked that and it works😳not sure if that was it or not but thankful it is now working. Thank you for reaching out. Roxanne
Sent from my iPhone
@Xrayrox thank you for the update.
Really happy to hear that your issue was resolved. As this is the case I have cancelled the ticket but if you need help don't hesitate to let me know.
I'll be around!
My issue hasent been resolved nor have I been contacted by Fitbit
@AlvaroFitbit @My issue has not been resolved nor have I been contacted by fit bit @Xrayrox‘s post was just a recommendation and it has not worked
@Tictok123 thank you for your reply.
My last reply was addressed to @Xrayrox . I have even mentioned them in said reply. Please wait until Support contact you directly so then can assist you.
I'll be around.
Did this get resolved. I am having the same issue, charge 3 has list all ability to vibrate!!
I resolved it myself. I did all the typical things and none of them worked. I had just replaced my band when this occurred so I figured I may have caused it by touching a setting on the actual fitbit. Under settings was a part that said sleep 10 pm to 6 am . Not sure where it came from how it got there but I checked it off and that was it🤷‍:female_sign:Not really sure what went wrong or how it got fixed. Probably not helpful, sorry. But it was the actual fitbit settings
Sent from my iPhone
