05-10-2020 11:39 - last edited on 09-17-2020 09:38 by
More and more frequently I am having trouble syncing my Charge 3. It is not even a year and a half old. Every few days This past couple of weeks, I have run across this issue and cannot get it to sync. I log off and on, turn Bluetooth off and on, reset my Charge 3, turn my phone off and on, try replacing the device, NOTHING works. Until eventually it does. And at that point I’ve lost a bunch of data from that day. Does anyone know why this is happening? Is it the version of the app (I have the latest)? Is the Fitbit only ever good for this long before you have to replace it? It’s my third device and I never get two years out of them. I am extremely frustrated and nearly ready to give up on Fitbit and chose a different tracker.
05-10-2020 11:52
05-10-2020 11:52
I also have experienced this and my device is less than a year old. I read to delete the app and re-install but that didn’t work either. I’m ready to turn it in.
05-10-2020 12:05
05-10-2020 12:05
It is extremely frustrating. There are so many steps they tell you to go through. I do them all about ten times and then suddenly it will work. No rhyme or reason!
05-10-2020 12:19
05-10-2020 12:19
Yes me too. I wondered if it was the new update. Very annoying!
05-10-2020 12:23
05-10-2020 12:23
I wondered the same thing as it’s happened previously then all is fine for a while, then back to having issues again.
05-10-2020 12:29
05-10-2020 12:29
I’ve messaged Fitbit. See what they do...
05-10-2020 12:39
05-10-2020 12:39
I just updated my iPad and iPone to iOS 13.4.1. My Charge 3 now will not connect. It says it see it but it will not connect. Very frustrating.
05-10-2020 13:11
05-10-2020 13:11
thanks for letting me know. Now I’m convinced it’s the update!
05-10-2020 13:57
05-10-2020 13:57
05-10-2020 14:00
05-10-2020 14:00
I spent an hour on it yesterday only to have the same problem today. Argh! I hope they come out with an update again real soon!
05-10-2020 19:53 - edited 05-11-2020 12:18
My Fitbit Charge 3 is only 2 months old. Had to replace a previous one. Two days ago it stopped syncing unless I completely shut it off, wait for the Happy face and bring it back to life. Then it syncs once. The Sync now option in profile also doesnt work, it refers me to settings and then closes the sync now option. Any ideas what has caused this. An update? UPDATE: I am pretty sure it is to do with the IOS updates that came on to my devices on the weekend. I have a really old IPAD and (not updated) and it was able to sync right away.
