10-22-2020
04:05
13:24
10-22-2020
04:05
13:24
My fitbit will not sync since September. I've tried allowing the battery to run out, charging it fully again. Restarting my phone, deleting the app and reinstalling it. It appears stuck on the failed sync from September.. The app doesn't require an update. I've search Google and forums and have tried the suggestions. My fitbit was purchased less than one year ago
10-25-2020
12:35
07:15
10-25-2020
12:35
07:15
@Denise1984 It's good that the community is growing!
Let me help you with your Charge 3 not syncing and thank you for troubleshooting this issue. You can try the following:
Let me know how it goes.
Best Answer10-25-2020 13:04
10-25-2020 13:04
I'm having the same issue. I have tried all of the steps outlined here. When I try to pair, it says "We found your tracker!" And then just tries to connect for a few minutes and fails.
Best Answer10-25-2020 13:58
10-25-2020 13:58
I am also having the same problem after using the watch for about a month. Having run through all the steps and then finally disconnected the watch and then tried to re set - up., now it won't even set-up. Tried both with my motorola phone and surface computer. no luck. Tried to do a tech support chat. After confirming I had done all the troubleshooting right, the only suggestion was that my devices weren't among the very few that are listed on the fully tested list, so they couldn't help. I am astounded and disappointed. The Charge 2 worked just fine on the motorola phone.
Best Answer10-25-2020 14:11
10-25-2020 14:11
I am having the same issue for about the same amount of time. I have tried everything. I did reboot my charge 3 a couple of times and that allowed it to sync but that is now no longer working.
I purcahsed my fitbit last December so have also had it less than a year.
I hope there is some solution to this.
Best Answer10-25-2020 14:18
10-25-2020 14:18
I also wanted to add that my fitbit no longer vibrates when I reach 10,000 steps, or as a reminder to move.
I have checked all the settings and have vibrations set to strong but still nothing.
