Charge 3 won’t pair or sync with iOS devices
I have tried all the tricks of turning off, turning back on Bluetooth on iPhone, putting Charge 3 in the charger and holding the side button until the 🙂 appears, holding my mouth sideways, etc. Nothing is working. It seems to have started after the latest software update on my iPhone. Is anyone else having problems?
272 REPLIES 272
fit bit charge 3 will not pair with iPhone
I managed to chat with Fitbit help and I have done everything they suggested switched things off and back on deleted app and reinstalled twice nothing is working Apple did an update yesterday all I can think of is there is a glitch in between the update and the app.  Other Bluetooth devices connected to my phone so I know Bluetooth is ok.  My phone just keeps saying no device found.. if anyone has any other tips apart from reinstalling app or switching phone/blue tooth on and off and restarting Fitbit charge 3 .. sure would like to hear from you.. sooo annoying
What version iOS are you running. I am having the same issue with version 13.3.1
Thank you for the reply. This has been my experience as well since updating my iPhone yesterday. I can pair with other bluetooth devices, just not my fitbit. My workphone has not updated yet and I could pair with it. Hoping that fitbit pushes a fix soon.
Version installed on iPhone yesterday 13.4.1
Yes me too.
Moderator edit: removed personal information
Me too 🙄😟😟
I’m having the same issues. Charge 3 is collecting data but it can’t sync to the app. My daughters Ace2 for kids won’t sync either.
I’m on 13.4.1 updated last night Sw on iPhone
Just spent an hour (1/2 hr on hold and 1/2 hr with support rep who couldn’t wait to get off the phone) but I have had success with the sync problem I reported this morning.
the solution is:
you need to login to your account from another phone. Before attempting to log in you need to turn blue tooth off your phone. My second phone automatically sync when I logged in and displayed correctly. I logged out of the second phone and then logged into my phone and the phone did sync properly. Problem resolved for now😀 good luck.
what if you don't have another phone?
Mine started late last night has been the last update. Done everything and could not get it to pair on iPhone or iPad.
Exactly the same has happened to me following same update on iPhone
Every time there is a iOS update on the iPhone the charge 3 stops syncing. Bluetooth will not pair up. All the steps were followed to make this happen rebooting phone, turning Bluetooth off and on, resetting charge 3 without result. This is becoming very frustrating
I’m having the same problem. Happens every time with iOS update. Tried all the steps to remedy this without result. Very very frustrating.
I haven’t got a second phone to do that! I’ve tried everything!!
My charge 3 wouldn’t sync to my iPhone so I’ve uninstalled and reinstalled but now it won’t pair again. I’ve tried everything on line to try and fix it. Help!
I updated this morning to the 13.3.1 & that’s when my problems began. I’ve done everything but nothing works. 😡
Same issue. Cannot sync charge 3 since update. Have tried all tips. No luck.
