05-11-2020 05:38 - last edited on 09-17-2020 09:38 by
I have tried all the tricks of turning off, turning back on Bluetooth on iPhone, putting Charge 3 in the charger and holding the side button until the 🙂 appears, holding my mouth sideways, etc. Nothing is working. It seems to have started after the latest software update on my iPhone. Is anyone else having problems?
05-12-2020 07:50
05-12-2020 07:50
05-12-2020 08:02 - edited 05-27-2020 14:46
I was just sitting reading the suggestions and was in the Bluetooth settings and pushed the “Forget this Device” then pushed to pair again and viola it reconnected and my Fitbit App synced and refreshed. This really works
05-12-2020 08:50
05-12-2020 08:50
05-12-2020 08:51
05-12-2020 08:51
05-12-2020
08:56
10:00
05-12-2020
08:56
10:00
Yes . I have just done the same via Bluetooth settings and it worked. I had tried this previously without success but hey ho it works now. Thank you
Nik
Moderator edit: removed personal information
05-12-2020 09:01
05-12-2020 09:01
05-12-2020
10:25
10:34
LanuzaFitbit
05-12-2020
10:25
10:34
LanuzaFitbit
Hello everyone! I apologize for the late response to you all, due to recent events affecting our operations, we're taking longer to respond.
I'm sorry to hear about the syncing or pairing difficulties you've been experiencing with your Charge 3 and iOS devices. I appreciate your feedback for the Fitbit Charge 3 and your efforts in solving the issues.
Please note that our main purpose is to avoid negative experiences to our customers, we're always willing to help and provide troubleshooting steps.
I've seen some of you have already contacted our Support Team, I'm glad for the ones who the issue is now fixed, but for the ones who are still working with our Support Team I'd suggest to keep your conversation with them as they know what's the next step to try after everything you and our team have done together.
I'm here to assist rest of you who still need help. I'd like to start confirming that everyone has followed the troubleshooting steps provided in these help articles: Why won't my Fitbit device sync? or Why can't I set up my Fitbit device?
If you have done as described in the articles, please check the following:
- Open Settings app on phone
- Scroll down, tap Fitbit -> Toggle Location to 'Always'
- Ensure toggles next to Bluetooth and Background App Refresh are turned ON
If the above has also been tried, please do the following:
1. Remove the Charge 3 from the Bluetooth settings (in case you have more Fitbit devices that are no longer in use, please also remove them). Also,
2. If you use to use more than one iOS (Android or computer also) device to sync, please remove the Charge 3 from all phones you may have it connected to.
3. Restart your Charge 3 once again.
4. Turn off other Bluetooth connections when not in use.
5. Plug it into the charging cable and open the Fitbit app.
6. Setup your Charge 3 again to your main phone and please make sure that other devices aren't nearby.
Give this a go and let me know if the steps recommended work for you.
05-12-2020 10:31 - edited 05-17-2020 14:46
05-12-2020 10:46
05-12-2020 10:46
Have just got mine to sync with iphone X (problems since most recent update).
Told Bluetooth on phone to "forget" the charge 3.
Plugged the charger into the laptop and popped in the Charge 3 expecting to have to pair it from scratch.
It synched and paired very quickly, but did give me an anxious minute when it showed twice my steps for today as the total. Has now behaved and is showing as connected in iphone bluetooth settings for the first time since the iphone update.
05-12-2020 10:48
05-12-2020 10:48
05-12-2020 10:49
05-12-2020 10:49
Have just managed to do this. Told iphone bluetooth to "forget" my charge 3.
Started process to pair it again by plugging it into the charger connected to my laptop.
It worked - didn't have to pop in a pairing code either. The iphone somehow picked up the device and connected it via bluetooth as usual and it synched.
Good luck!
05-12-2020 11:00
05-12-2020 11:00
Thank you!!! I am back in business!
05-12-2020 11:06
05-12-2020 11:06
05-12-2020 11:10
05-12-2020 11:10
05-12-2020 11:13
05-12-2020 11:13
05-12-2020 11:20
05-12-2020 11:20
05-12-2020 11:25
05-12-2020 11:25
05-12-2020 11:56
05-12-2020 11:56
I started having the same issue after my IPAD updated. My Fitbit syncs with my Android just fine and also when I use the website but my IPAD app says no device found and Bluetooth settings will not connect. I sent several messages to support on twitter but still no response to the problem.
05-12-2020 11:58
05-12-2020 11:58
my old charge 2 still can sync with my iPhone, while cherge 3 cannot. I tried to restart the tracker several times but still not working.. there is iOS 13.4.1 running on my phone; I do not know when it was updated
05-12-2020 12:00
05-12-2020 12:00
I just updated to 13.4.1 on my IPAD and I tried everything imaginable to get it to connect. I deleted the app, rebooted my Charge 3 several times, and it still won’t connect. Very frustrating indeed.
