09-30-2018
18:38
15:47
09-30-2018
18:38
15:47
I know there are only like 3 people that have this device right now, but if anyone else that has it can check...is yours syncing ok? Mine last synced 4 hours ago and when trying to force a manual sync it wouldn’t get past “looking.” I tried the usual fixes - turning bluetooth off and on, removing the C3 from the app and my phone and attempting to re-add it, power cycling my phone...nothing works. The user manual says to press the side button for 8 seconds to reset, but all that does is bring up the screen wake/notifications toggle screen. Just issues due to it being new/unreleased, or is it possible it crapped out on me already?!
04-01-2020 09:10
04-01-2020 09:10
Under Bluetooth, I have Charge 3 listed, but doesn’t have the ”i” symbol, so I can’t forget the device and start the setup again. It says connected, but the device won’t start, 8 second hold on button does nothing. What to do?
04-01-2020 09:15
04-01-2020 09:15
04-01-2020 12:32
04-01-2020 12:32
I am having the same problem. Called Fitbit 3 times and no one can figure it out. We rebooted4 times,turned Bluetooth off and on several times, removed Fitbit several times. One person said it was on their end at Fitbit but the other 2;people hadn’t heard that. One person said it could take 2 weeks for it to sync but I don’t think they have the answer
04-01-2020 14:39
04-01-2020 14:39
If you don't want to loose data go to settings in your phone and force the app to stop (android devices - not sure if this also works for apple) then restart and your app should pick up the c3
04-01-2020 15:04
04-01-2020 15:04
04-01-2020 15:37
04-01-2020 15:37
04-01-2020 18:46
04-01-2020 18:46
04-02-2020 18:06
04-02-2020 18:06
Thanks, worked for me!
04-02-2020 21:54
04-02-2020 21:54
This happens to me quite frequently with my Fitbit Charge 3 which I have had for two years. And yes, the tricks they suggest to fix the issue do help and the sync will work for a few weeks (or sometime days) but invariably it always returns. Not just on my laptop but on my iPhone too. It's annoying to say the least.
It's not my laptop or iPhone. It's the Fitbit Charge 3 and it's bluetooth. It's par for the course with bluetooth. I am so used to this happening, that I just shrug, employ one or two of the tricks and move on. I used to cuss and fuss in the beginning but now I just smile when it happens, execute one or more of the "fixes", which always work.
For the record, I like my Fitbit. Been using one since 2013 (a couple of Ones, a Flex, then a Charge 2 and then this Charge 3). It's not worth complaining about it; if you like your Fitbit(s), you learn to live with it.
04-03-2020 03:26
04-03-2020 03:26
04-03-2020 03:43
04-03-2020 03:43
04-03-2020 04:15
04-03-2020 04:15
04-20-2020 12:47
04-20-2020 12:47
I also have troubles syncing my Samsung Galaxy S7 with my fitbit charge 3. Had a charge 2 before and the sync was much better. Every week I had to restart my fibit and phone to solve the syncing issues. After 7 months my fitbit Charge 3 gave up! The screen was going nuts (on and off, and vibrated every 10 seconds. I send it back and luckily the company I bought it from contacted me that it could not be fixed and I got a whole refund. I hoped the problem was only with my charge 3 and I could by a new one and have a better experience, but as I read the messages in this thread.....mmmm, now I am wondering if fitbit charge 4 is any better.
04-20-2020 18:28
04-20-2020 18:28
How were you able to get the C# to sync with the new account? I tried that as well. I can't even do a hard reset of the C# because when I hold the button to do the reset it immediately clicks over to Fitbit Pay.
04-20-2020 19:37 - last edited on 06-08-2020 19:59 by LiliyaFitbit
after a long time of sync issues
The stair count also became inaccurate.
After email support, the Fitbit was replaced with a new charge 3
Regards
Eric
Thank you in advance,
04-20-2020 19:48
04-20-2020 19:48
05-24-2020 12:36
05-24-2020 12:36
I have the same problem with my FBC3... did you ever get it rectified?
05-24-2020 12:44
05-24-2020 12:44
Yes - I called Fitbit Customer support and after several minutes and trying a few things I was sent a new Fitbit Charge 3 free of charge! I am most satisfied.
05-24-2020 12:54
05-24-2020 12:54
I had 6 or seven replacements, every one went the same way, paired and worked initally then the same problem came back. Hope yours is ok but I wouldn't hold my breath.
05-24-2020 12:55
05-24-2020 12:55
I finally got a refund.
