12-14-2022
07:17
05:29
12-14-2022
07:17
05:29
Good morning, my Charge 4 is not syncing. Can you help?
12-14-2022 10:33
12-14-2022 10:33
They will not be able to help, its due to the last android update which wasnt tested by fitbit
Best Answer12-14-2022 13:37
12-14-2022 13:37
Mine is doing the same, the only way I can get it to sync is forget the device on Bluetooth, go back into the app, turn off Wi-Fi, sync and ew-pair when prompted. However it need to be down every time I go into the app. Very annoying.
