10-05-2017
13:50
09:56
AndreaFitbit
10-05-2017
13:50
09:56
AndreaFitbit
This morning my fitbit started displaying the wrong time (off by 3 hours) I tried to "reboot" by plugging it into charger and holding down the button until reset...... I've tried that 5 different times and resyncing it to my phone..... it didn't work 😢
10-06-2017 08:15
10-06-2017 08:15
Aloha my friend @Leesaloo, it's great to welcome you to the Fitbit forums. I would like to thank you for trying the restart process to fix the inconvenience with the timezone. If you'd like to give the Fitbit chance, I suggest following these instructions based on the platform you're using to sync the tracker:
Hope this helps my friend and let me know the outcome!
What's for breakfast?Check others recipes and share yours!
01-13-2020 17:53
01-13-2020 17:53
This happened to me too! I went into advanced settings and changed it to a completely different time zone and synced my fitbit to that. When I went in and synced it to my time zone it changed back to what it should have been. Hope this helps!
03-25-2022 14:07
03-25-2022 14:07
Mine has done it twice today both times when I synced the watch it has gone back to the correct time. I have not been more than 5 miles from my house. I looked in settings nothing looks wrong
03-25-2022 16:09
03-25-2022 16:09
Okay - once again this has happened to my Charge 3. First time was last night when it suddenly jumped ahead 4 hours. I rebooted/restarted twice & it finally went back to the correct time. Just now it jumped ahead 4 hours AGAIN. Rebooting/restarting has done NOTHING. I should NOT have to deal with this repeatedly. What say you Fitbit??? Because since this is happening repeatedly to a number of people, it's obviously a problem at your end.
03-25-2022 16:12
03-25-2022 16:12
And please - can someone tell me why I keep getting this inane microscopic message telling me to make sure my mobile app "permissions" are enabled?? I don't know what the heck that means or what I'm supposed to do about it. Geesh.
05-03-2022 00:27
05-03-2022 00:27
This happens to me when I’m in my mansion just chillling!😡😡😡
02-16-2023 00:27
02-16-2023 00:27
My Sense 2 did the same exactly this morning. Rebooting several times did not help. Any suggestions?
