05-27-2016
11:45
20:15
05-27-2016
11:45
20:15
Hello all!
I am troubleshooting my Fitbit Charge HR. I fully charged it less than 24 hours ago and it recently showed the battery icon, with the exclamation point inside. Shortly after I noticed that icon, the display no longer showed anything and the green lights on the backside stopped working. About two hours ago, I plugged in my Charge HR to charge the battery (which seemed unnecessary, since I fully charged it recently) and it, once again, showed the battery icon with the exclamation point.
When I unplug it, the display shows nothing. Now, when I plug it back in, it will show the battery icon with the lightning bolt symbol. This problem persists, no matter what I try. I cannot reset the device. I have up-to-date firmware and Fitbit Connect software. Furthermore, after charging for a while, the Charge HR feels hot.
I truly hope someone can help me!
05-27-2016 14:23 - edited 05-27-2016 14:24
Contact Customer Support -- http://help.fitbit.com/?cu=1 I recommend the CALL US or LIVE CHAT options. Links for those only appear when someone is available to help you.....
Best Answer08-27-2020 15:53
08-27-2020 15:53
Also having issue with an exclamation point on battery on device. Tried everything but nothing is working to fix this problem. To be honest, I’ve owned a few different types of Fitbits, and this Inspire HR has been nothing but problems!! Hope you have finally found a way to fix your issue with yours. I am still trying!
