09-22-2019
04:39
12:50
09-22-2019
04:39
12:50
My battery is dying sooner. Can it be replaced?
09-22-2019 04:41
09-22-2019 04:41
The battery can't be replaced but if you are covered by warranty then you may be eligible for a replacement fitbit. Best thing to do is to contact customer support via contact.fitbit.com If they can't fix it they can check your warranty status and advise on your options.
Best Answer09-22-2019 07:50
09-22-2019 07:50
Try this, post 26 in this thread:
