One week ago my charge2 stopped to track heart signal. Two days ago it
suddenly turn off and have fixed green sensor lights. Nothing appear on display. If I charge it, then the battery icon appears as usual. When fully charged I wear it , it works (w/o hearth signal) but after a few mins it turns off again.
I try to connect to laptop and esclamative mark symbol is shown on the display.
Any help would be really appreciated 😞
Welcome to the Fitbit Community, @Giotrail. I'm sorry to hear your Charge 2 doesn't turn on anymore.
When you get the exclamation mark symbol may be the battery not charging properly. Please follow these steps:
Make sure you use the charging cable that came with your device, as most cables aren't compatible with other devices.
Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer@AndreaFitbit I cleaned the device and still using same cable as I have been done until now without issue. The Fitbit got full charged but after some mins run out of battery (4%).
What sounds strange is that the sensor lights are fixed and not blinking as in the past . However it is tracking and syncing even if screen is black (battery with esclamative mark).
Any suggestion ?
Thanks for getting back to us and for mentioning the steps you have followed @Giotrail.
As I mentioned on my previos post, please contact our Support team for further assistance.
Keep on visiting the forums.
