02-04-2019
13:18
20:07
02-04-2019
13:18
20:07
After a month I started getting this and it won't do anything else.
02-04-2019 16:00
02-04-2019 16:00
Mine too! and it will not sync or reset. Anyone have any info?
Best Answer02-12-2019 14:05 - edited 02-12-2019 14:05
I don't understand why Fitbit doesn't have the answer for this problem, they should know how to fix it.
Best Answer02-17-2019 17:02
02-17-2019 17:02
Mine too. Same thing. Hope someone can help.
Best Answer02-18-2019 06:42
02-18-2019 06:42
Did you ever get an answer. Same thing is happening here.
Best Answer02-20-2019 08:39
02-20-2019 08:39
Hi @Lonewolf269. I‘ve asked a moderator to step in. I have no other suggestions other than to reset. @ABC--- has tried the reset. I’d suggest others in this thread also try it. Do the reset process 3 times.
Best Answer02-21-2019 07:04
02-21-2019 07:04
@ABC--- @brenda79 @Ldhatch Welcome! Thanks for being part of our Community! @Lonewolf269 I hope you're doing well!
Have you tried updating the Charge HR firmware recently? This could be the reason you are seeing this progress bar. I would suggest that you start by going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device like @SunsetRunner suggested. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. Finally retry updating the firmware on your device or look for any available update for it.
Let me know how it goes!
Best Answer02-21-2019 09:05
02-21-2019 09:05
02-21-2019 11:48
02-21-2019 11:48
@Lonewolf269 thank you for your reply! You can follow these instructions to update your Charge HR. If the issue persist then please try a factory reset. You will need to setup the tracker after this.
