06-11-2020
07:13
09:30
06-11-2020
07:13
09:30
About a week ago, I discovered when scrolling back to compare yesterday's data, it was showing today's data on distance. It then started to show today's data for floors as well. As I scroll back, it momentarily shows the correct data for the day in question, but quickly reverts to today's data, under the above two icons, despite showing the previous date. I have disconnected and reconnected blue tooth. Deleted and reinstalled the fitbit app. I have reset my fitbit and restarted the phone, but the problem persists
06-16-2020
08:10
05:52
06-16-2020
08:10
05:52
@JaneB15 I hope you're doing well!
Let me help you with your Fitbit app showing current day's data on previous dates and thank you for troubleshooting this issue. I suggest you log out from the app, restart your phone and log back in. After this make sure your app has enough time to load previous days data as this is pulled from the Fitbit servers. Also try different connections, for example if you are using your wifi connection then try mobile data connection or vice-versa.
Let me know how it goes.
Best Answer06-17-2020 17:45
06-17-2020 17:45
I'm having the same issue. I tried the suggestions above but no luck. When I scroll thru days, it will momentarily show the correct cal count but then reverts back to the current day's value.
06-22-2020 12:19
06-22-2020 12:19
Same issue here also. I have been for a walk today and when I came home had 12,000 steps showing on my Charge 3, the time and date were the same as my iPhone. I synchronized with the App on my iPhone and both the App and watch then showed Zero steps for today and todays data is showing as Yesterday's data.
I have checked the region on my Iphone, App and they are correct. I have rebooted my Charge three times, I have signed out of the App, restarted the iPhone and restarted App and synched and still the App & Fitbit show zero exercise for today.
