07-15-2019 10:29 - last edited on 11-17-2020 10:55 by MatthewFitbit
Having problems syncing my phone Samsung charge 3 keeps saying no device found I have turned my phone off and back on several times as that usually works but no joy this time.
Can anyone suggest any ideas
Thanks Sue
07-15-2019 10:55
07-15-2019 10:55
I am having the same problem today. Anxious to hear what replies you receive.
07-15-2019 12:03
07-15-2019 12:03
I have a similar problem synching to an iPad. This problem started several days ago. I can usually get the tracker to synch to the app after a morning workout but not much more frequently than that despite doing nearly everything the forums and instructions say to do. Also, the time of day displayed on the clock face now loses several minutes per hour until I can finally get it to synch. Ugh.
07-15-2019 12:16
07-15-2019 12:16
iPhone here, but same problem. Always been an issue with the Charge 3 started happening many times a day with the latest app update, worse still after the firmware device update. Says sync'd but clearly didn't, but mostly just looking for device/can't find device. Rebooted fitbit, fitbit app and phone many times per day. Usually can get it to work eventually. Reset the FitBit several times too.
What is up with the Charge 3???? This is a warranty replacement after the first one did the same thing and finally wouldn't connect or reset anymore. I restart the device and app more per day than I did my FitBit One in three years!!!!
07-16-2019 06:14 - edited 07-16-2019 15:41
I received notification for a "Charge 3 Update Available". I followed the instructions perfectly, including making sure that Bluetooth was enabled, that I had an active internet connection, that the tracker was close to the mobile unit and that the battery was charged. After pressing the pink "Update Tracker" button, I now get either a "Something went wrong while loading the firmware update" or "Something went wrong There was an error while trying to update your device." message. I appreciate that there is concern that the Charge 3 needs to be updated, but I can't get the update to work.
EDIT: Fitbit offered to replace the device.
08-10-2019 09:37
08-10-2019 09:37
I am having the exact same problem and with my Samsung phone. Did you get an answer about this? And I am so fed up with having to go through the troubleshooting routine every day just to sync the device.
08-10-2019 10:01
08-10-2019 10:01
I went through the recommended routine with customer service over the phone and they sent a new Charge 3 to me. The new one works so far.
08-10-2019 11:33 - last edited on 07-08-2020 20:27 by LiliyaFitbit
This one IS a replacement. The first one was even worse.
Moderator edit: format
08-10-2019 13:15
08-10-2019 13:15
08-10-2019 18:43
08-10-2019 18:43
After spending almost an hour on the phone with Fitbit - my understanding is that this is a problem with the app and there is no fix for users. I ended up installing the app on my computer and was told this is the only "reliable" way to sync. I will continue to get the message "no device found" on my phone and will have to continue to follow the troubleshooting steps (reboot device, force stop, etc.etc.) to get the Charge 3 to sync. And even then - who knows?
I do so regret this purchase.
08-10-2019 20:06
08-10-2019 20:06
Just wondering if you lost all your data, previous workouts, when you deleted the charge 3 then repaired with bluetooth. I just don't want to lose all my previous workout data.
08-10-2019 20:25
08-10-2019 20:25
08-10-2019 21:28
08-10-2019 21:28
08-10-2019 21:32
08-10-2019 21:32
09-22-2019 18:26
09-22-2019 18:26
I also am having issues with my LG G6 not finding my Charge 3. I have reset the fitbit, and restarted my phone, it will work for days, then after this last update yesterday, no go. Its as if they fix for one phone and it messes up other phones. OMG, so frustrating
09-23-2019 05:42
09-23-2019 05:42
I spoke with FitBit about this because I was fed up. They had me download the app to my computer (not the dashboard but the app itself) in addition to having the app on my phone. Since then it has worked fine. I am not syncing to the computer (so to speak) but for some reason I don't have problems anymore.
09-23-2019 08:02
09-23-2019 08:02
10-08-2019 12:43
10-08-2019 12:43
I continue to be frustrated with trying to sync my Charge 3 to the app on my Samsung phone. Have tried everything from turning blue tooth on and off, rebooting phone, uninstalling/reinstalling the app, force stop the app, reset the Charge 3 and nothing seems to work. Eventually it will sync on its own but many times when checking in the a.m., the last sync was the evening before - 8 plus hours. Syncing has always been an issue but now it is constant and almost seems to be worse since they started to promote their Premium upgrade package. Given all these issues, I would not even think of paying them for the Premium package when they can't seem to get the basic app to work efficiently. I am tolerating this but having a very poor user experience. Hopefully they will find a fix soon.
10-08-2019 12:54
10-08-2019 12:54
Have you installed the Fitbit app on a computer or tablet in addition to on your Samsung phone? I don't mean the Fitbit dashboard, I mean the Fitbit app. I had called Fitbit customer support because I was having the exact same issues you are. and they had me install the app on my computer. Since then I have had ZERO issues and it has worked perfectly. I don't even look at the app on the computer or sync to it, just on my phone. Worth a try!
10-08-2019 13:14
10-08-2019 13:14
Thanks for that suggestion. I forgot I even had it on my Kindle. So I just uninstalled/reinstalled on that device and we shall see. Fingers crossed. Thanks!
