01-25-2016
09:33
17:10
01-25-2016
09:33
17:10
How do I brighten the display light on my Charge Fitbit? The display shows up but its very dim and not as bright as it used to be? Please help!
01-28-2016
03:06
09:20
01-28-2016
03:06
09:20
@k_FIT Welcome to our Community! While @SteveH is right when explaining that there is no setting to adjust the screen brightness if you are saying that it was brighter then this could mean your tracker may be having a malfunction. Please fully charge your device and restart it. If this doesn't correct the issue then contact our Support Team. They should be able to assist you with this situation.
Keep me posted!
02-28-2018
06:45
09:20
02-28-2018
06:45
09:20
@Germnawind Welcome to the Fitbit Community! It's great to have you here! Have you tried the restart suggested in my previous post? Please try it and let me know if this worked. Could you also share some pictures of your tracker's display?
I look forward to your reply!
10-21-2018
05:49
08:01
MarcoGFitbit
10-21-2018
05:49
08:01
MarcoGFitbit
It happened to me as well! I could only read the time and nothing else! So, I called Fitbit and luckily I had a warranty on it and they gave me a free new one or a chance to get 50% off another purchase with Fitbit! I chose the new free one and it just came it works amazing!
Moderator Edit: Format.
11-07-2018
08:03
08:50
11-07-2018
08:03
08:50
Hello @charchar06, I hope you're doing well, it's nice to see you around the Fitbit Community. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. I'm very glad to know you were given a replacement after contacting our Support Team.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
07:30
18:53
JuanFitbit
08-25-2019
07:30
18:53
JuanFitbit
Mine was under warranty so had it replaced.
Moderator edit: removed personal information
Best AnswerMine too. When I reset it, it’s bright for a second then dims to “normal mode” again. I can never read it outside. I have a feeling this is a software glitch, or perhaps even more sinister, a planned glitch to make us buy more fitbits. Either way, it sucks.
Does this mean the light will never work again?
