11-30-2018
09:17
14:34
11-30-2018
09:17
14:34
I have just had to return my Charge 3 after only buying it on 3/11/18.
Display stopped working for no apparent reason. Store Tech said he had never seen it happen before. So replaced it. So not impressed.
Welcome on board @CarterW! Thanks for letting us know worked for you. While reading your post I was wondering if maybe the new clock face you've set is no letting you to see other data? Have you try testing different ones?
Hey guys @Cedars and @Pirate21, It's nice to see you around the forums! I'm glad to hear that the steps worked for you. Thanks for sharing the outcome! ![]()
Thanks for jumping in here @MING8388 and for restarting your device! Have you tried changing your clock face?
I'd recommend performing the long restart:
In regards to your sleep not tracked, I'd recommend taking a look at this post.
Looking forward to your reply!
Hey there @fifib, thanks for stopping by! Sorry to hear about the inconveniences you had with your previous Charge 3. I totally understand where your concern is coming from and I really appreciate your feedback.
Thanks for jumping in here @Wamukota! If your tracker's display is not working, I recommend restarting it by doing the following:
Let me know how it goes. ![]()
Thanks for jumping in here @Grumpy! Sorry to hear you've been experiencing the same inconvenience with your Charge 3's display.
Please try following the restart I've provided here.
Give this a shot and let me know the outcome!
Sorry to hear you go @Wamukota!
Thanks for trying the tips and recommendations provided. Don't hesitate to ping me out if you need further assistance, I'll be around!
Best AnswerThanks for the info needed to get my display working again but I am concerned as to what is causing it. This smartwatch has so much potential if it could just get by all the problems it has.
I have had my Charge 3 for 2 months & the display has stopped working. I have tried the restart & get nothing on the screen.
I get 2 vibrations about 3 seconds into the 8 seconds, but no smiley face or anything. It still tracks everything, I just can't see it until I sync.
Now what?
Best AnswerHello! Mine did the same. Just wouldnt work. It was vibrating, countjng steps and all else. I attempted to change the clock face in the fitbit and when I chose a new one the screen started working again. Maybe some kind fo glitch? I don't know.
@AldaSilva wrote:Hello! Mine did the same. Just wouldnt work. It was vibrating, countjng steps and all else. I attempted to change the clock face in the fitbit and when I chose a new one the screen started working again. Maybe some kind fo glitch? I don't know.
Thank you so much for this suggestion. The display on mine would not turn on just now, even though it was clearly working. I changed the clock face, and voila, it's working again!
My display stopped working last night as well after only having my FB for about a month but did the reboot and it worked. Must say I was surprised it did that already as it’s so new. I’ve noticed too that it doesn’t send my notifications to me now and isn’t showing my days of activity on my FB display but does on the app. I do love it though and so happy I got it....just hope it lasts a long time!
Best AnswerMy Charge 3's display went off in between, I read your reply and the band has restarted itself. What was the problem that had occurred? If it's some software issue kindly fix it . Also Fitbit needs to update it's food stats page as it doesn't take into account a lot of food items and the MyFitnessPal from Under armour does a much better job at tracking your food calories and the food items that have been consumed.
Had the same issue. Wasn’t happy but researched first. This procedure solved the failed display issue. If it happens again then maybe a return under warranty.
