03-31-2016
16:06
20:15
03-31-2016
16:06
20:15
My Charge HR decided it no longer wanted to sync to my iphone, deleted the app and did all of the regular stuff to no avail. I then decided to try sync it to the PC - after about 5 minutes it would tell me that it had lost connection.
I then attempted a hard rest, after showing VIBE, the screen comes up with ERROR 0x0009.
Has my FitBit had it? Quite annoying, it's only 3 months old.
08-10-2016 20:52
08-10-2016 20:52
I have tried Android, Windows phone and Windows PC. Every device will have the same synching problem with Fitbit.
What this error 0x0009 stands for? Why it's showing it during factory reset?
08-31-2016 05:50
08-31-2016 05:50
I have had the same issue, I contacted fitbit 3 times and went through lengthy fixes. I was told they do not know what the error 0x0009 means. The customer representative said he has notheard of anyone with this problem. I am beginning to lose faith in the product. I have had the syncing problem 3 times over 2 weeks. Once it tried to sync and just flashed the correct info and then went back to not syncing. Anyone else getting frustrated.
08-31-2016 05:52
08-31-2016 05:52
I've had the same problem, you are not alone.
Best Answer08-31-2016 05:58
08-31-2016 05:58
I wonder who has done the FW if they don't even know the error codes for it. 🙂
And looks like no interest to fix it either.
Anyway, what's the point to make sport device which is not even water proof? Like swimming wouldn't be sport activity at all. I noticed this too late as it was not clearly mentioned in advertisement.
Best Answer08-31-2016 06:02
08-31-2016 06:02
I was very unhappy about the assistance I received on the phone and during live chat. They had me do the same things over and over. The representative did not know about the error message and I had to be very insistent before they would replace my tracker, but they finally did agree to send me a new one. I'm wondering if it is an inherent problem with the design.
Best Answer11-26-2016 12:21
11-26-2016 12:21
Hey Bzerk, I also had the same problem of not syncing with bluetooth, which already lasted for about two weeks now. I've been temporarily fixing it by soft resetting the Charge HR with the 12 second thing while being connected to a power supply.
Factory reset didn't happen by following what the official guide said, but your method worked like a charm on the error 0x0009.
Whether the Bluetooth syncing problem is a software or hardware, only time would tell...if I don't reply to this thread again, assume that it works out fine!
Best Answer02-25-2017 10:29
02-25-2017 10:29
the part that was left out at the end was to go into the app on your phone and set up the device. i was trying to connect using bluetooth setttings and it would not connect. after starting the app, it connected through the app itself.
Best Answer02-27-2017 10:22
02-27-2017 10:22
Hi @jayb1rd. Welcome to the Fitbit Community Forums!
You're totally right, when it comes to setting up a tracker as a new device, you need to do this from the Fitbit application and not from the bluetooth settings on your phone.
If you need any help, let me know. I'll be happy to assist!
Best Answer03-11-2017 10:34
03-11-2017 10:34
Doing this killed my Fitbit
08:50
05:48
03-13-2017
08:50
05:48
Hi there @Kenyamora. Welcome to the Fitbit Community Forums!
Did your tracker stop responding after performing the factory reset?
Have you tried to do a normal restart after that by pressing the button for 10-12 seconds while it's charging or does it light up when you put it to charge?
Best Answer01-11-2018 11:44
01-11-2018 11:44
Perfect....
12:18
04:54
01-11-2018
12:18
04:54
Hi there @FelipeRosati, great to see you in the Fitbit Community Forums! 🙂
Are you having any problem with your Charge HR that you need help with?
If so, let me know. I'm here to help!
Best Answer01-12-2018 05:12
01-12-2018 05:12
Best Answer04-11-2018 05:12
04-11-2018 05:12
This morning I went to go get my charger hr I think that’s what it is called but it had the wrong time would not sync or connected I went to do a rest and I got a error code 0X0009? Help ?
Best Answer11-26-2019 10:08
11-26-2019 10:08
I've had same issues, and then some, getting my charge hr to sync. Two calls to support got me no where. Fitbit help website gave me different, better info and I was able to resolve my issues (so far so good). Retraining might be in order for some. I have other Fitbits/electronics and I've never had more headaches than I've gotten from this Charge HR.
