05-30-2018 09:06 - last edited on 09-06-2020 20:07 by MatthewFitbit
My Charge HR is 2.5 years old, all has been great until this week. The display has been stuck in the same place for 4 days now. It tried to update the firmware and now I have the infamous half-bar of death.
Here is what I have tried:
1. Restart with the charging cable plugged in, hold the button, 2 seconds later disconnect and continue holding button for 7-9 seconds. I am a pro at this maneuver now, having done it about 50 times.
2. Remove the Charge HR from the Fitbit app on my iPad, then add it back in. I am unable to "forget this device" in the Bluetooth menu no matter how many times I tried, so I have to disable Bluetooth before I can remove the tracker in the app. I have gone through this about 20 times now.
3. Same process with the Windows desktop app. I have plugged in the dongle, opened the app dashboard and removed the tracker, and closed it. I then added it back in but no change. Yes I made sure the iPad bluetooth was turned off while trying this on my desktop.
4. Deleted the Fitbit app on my iPad and then re-installed it, added the tracker, but no change there. I have done this about 4 times now.
5. I just saw another thread where someone recommended turning off Notifications from Fitbit on my iPad while deleted and re-adding the tracker. Done, restarted, no difference.
6. Let the tracker completely discharge for 3 days and then tried removing and re-adding it to the app. No change.
Today I have just left it connected to the recharge cable, and left the Fitbit app running, and it is cycling through "updating", "syncing", and "locating" continuously for about 4 hours so far.
Any other suggestions?
Moderator Edit: Updated Subject for Clarity
09-08-2018 14:24
09-08-2018 14:24
03-22-2020 21:40
03-22-2020 21:40
@Fitbit facing big problem in setting up update on new bought versa2.more than 24 hours and firmware not getting updated, hence watch not getting on..can you please help.. can you give me India helpline
