05-25-2020
23:42
09:40
05-25-2020
23:42
09:40
Anyone that can help my screen went black but green lights still flashing and when pressed buzzes
05-27-2020 11:16
05-27-2020 11:16
Hi @Craig70 hope you are doing well!
First I would like to thank you for reaching out to us on fitbit support. Since the green lights are still flashing and your fitbit still buzzes when pressed,I suggest connecting your Fitbit to its given charger and then holding the button located on the side until the fitbit logo appears. Usually hold it for 10-12 seconds. Once the logo disappears, that means it has restarted. Once restarted try holding the button until your fitbit turns back on.
I Hope it all works for you!👍
05-27-2020 11:18
05-27-2020 11:18
Sorry for the delay in response and took a while by the way.
