04-21-2019
07:39
16:26
04-21-2019
07:39
16:26
My husband connected his Fitbit to the charger yesterday and the screen turned white with lines/static/fuzzy all through it. When he it unhooked it several hours later it was in setup mode, although he couldn't do anything with it. Now the screen is black when not on the charger. He's worn this tracker daily for quite a while and never had an issue. Did it just die? Is there anything he can do?
Fitbit Charge 2
04-24-2019 05:54
04-24-2019 05:54
Support said we'd exhausted all options and Charge 2 is dead. It lasted a little more than two years. They did send me a fairly generous discount to buy a new tracker, since the warranty is long expired. We bought a new Versa.
Best Answer04-21-2019 15:18
04-21-2019 15:18
So did your Fitbit die?
Best Answer04-21-2019 16:55
04-21-2019 16:55
I think probably it did. I spoke to support who had me clean the contacts and reconnect it to the charger, but now it's just black, no green light on the back, nothing happens at all. I'll try cleaning again, but I'm not holding out any hope.
Best Answer04-22-2019 07:15
04-22-2019 07:15
Did they say how long they last? I think mine is dying too
10:28
10:01
04-22-2019
10:28
10:01
@Wags55 @Gr8typist Welcome! It's good that the community is growing!
I will assist you with your Charge 2 display not working correctly. Try restarting your device by following these instructions.
Let me know how it goes.
Best Answer04-22-2019 17:20
04-22-2019 17:20
Thanks. We cleaned the contacts and put it back on the charger. It lightly vibrates when we attach it, but now the screen is totally dead. We tried resetting it and it does lightly vibrate, but the screen stays black.
04-23-2019
07:53
10:01
04-23-2019
07:53
10:01
@Gr8typist thank you for following my suggestions. Since the issue persist please let our Support team know for further assistance. I noticed that you already have a ticket with them so I wanted to know if they were able to help you?
I look forward to your reply.
Best Answer04-23-2019 08:02
04-23-2019 08:02
No, they just had me clean the contacts and try to charge it again. It didn't work. I guess I need to contact support again.
04-23-2019
08:16
10:01
04-23-2019
08:16
10:01
@Gr8typist yes please update them with the issue. Let me know that screen is still not working after their suggestions and ask them what else can be done.
Keep me posted.
04-23-2019 09:08 - last edited on 02-23-2020 16:53 by LiliyaFitbit
hiThanks ok will do
Best Answer04-24-2019 05:54
04-24-2019 05:54
Best Answer04-24-2019 09:53 - last edited on 02-23-2020 16:54 by LiliyaFitbit
wow that is good to hear about the discount they extended ....
I am sure mine is on its way out.
Thank for letting me know.
12:05
10:01
04-30-2019
12:05
10:01
@Wags55 @Gr8typist thank you for your updates and sorry for the late reply.
@Wags55 what did support tell you at the end?
@Gr8typist happy to hear that you got a discount from the team and that you bought a new Versa with it.
Keep me posted.
Best Answer02-20-2020 17:18
02-20-2020 17:18
I have the same problem after i drop my charge 2 =___= how to resolve this?
Best Answer02-20-2020 17:24
02-20-2020 17:24
Best Answer02-20-2020 17:26
02-20-2020 17:26
I dropped mine accidentally. It's not overcharge or something.
