11-28-2016
16:18
10:26
11-28-2016
16:18
10:26
Hello
I bought a Fitbit charge yesterday. After I unboxed it i found out that the display is permanently dim. First I thought i need to charge the battery, but after re charging the display stays dim and is very hard to read. I have tried to restart the Charge 2 but it won't chnage. display stays dim. Any idea whats wrong ?
@Markus1975 Welcome to our Community! This is odd, actually the screen is quite bright and the restart should have helped correcting this issue. I suggest you retry the restart but this time do it 3 times in a row by doing the following:
1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
2. Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
3. Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display. Your Charge 2 will begin charging.
4. Press and hold the button on your tracker for four seconds. When you see the Fitbit logo and the tracker vibrates, this means the tracker has restarted.
5. Unplug your tracker from the charging cable.
If the issue persist you can either return it to the place you purchase it from for an exchange or contact our Support Team for further assistance.
Let me know how it goes!
@Markus1975 Sorry to hear that the restart didn't work for your tracker. Still let me know how it goes with the new tracker once you receive it.
Keep me posted!
Best AnswerI also tried the restart method, but did not help. It is so dim it is hard to even see anything. What an inconvenience to have to return this to the store I purhased it from. It's a 1/2 drive to the store.
@Waldova Thanks for stopping by! Sorry to hear that your tracker isn't working as it should. Did you try the restart instructions on my previous post? If you had and the issue remains then the best thing you can do is contact our Support team for further assistance.
Best AnswerTried it several times. No change. Was fine for months but now so dim I can no longer wear it as a way to see what time it is...and wearing a watch and a Charge 2 is more than want to do.
@Waldova Thank you for retrying the restart. Did you contact our Support Team? What did they say?
Keep me posted!
Best AnswerThe same thing is happening with my charge 2. I cant see the display in the sun. Its very frustrating. Tried restarting it multiple times and nothing has happened. Im thinking of switching over to the apple watch.
Update: My charge HR 2 is officially done. The display is dead now. It still vibrates when you hold the button and the heart rate monitor is still on but I ant use it because of no display.
@Codyzhu @Jdldds Welcome! Thanks for being part of our Community! Sorry to hear about your Charge 2 display not working.
@Codyzhu Since yours isn't working at all and you mentioned that you have already restarted it then the best thing to do is letting our Support team know about this issue. They will review your tracker's data and warranty and provide options accordingly. You will get an email from them.
@Jdldds The Charge 2 is a little bit difficult to read under direct sunlight (this has been my experience) but you could vote for the idea of increasing the display brightness on our Feature suggestions board. The more votes an idea gets the more likely the developers will try to implement it. If you believe that this is abnormally dim then please try restarting your tracker by following the instructions in my first post.
Best AnswerThanks! I tryed this but it still stayed dim🙁
@Genevieve.McG Welcome! It's nice to have you on board! Sorry to hear about your tracker's dim screen and thank you for following my suggestions. Since this didn't work then please let our Support team know about the issue. They will review your case and provide options. You will get an email from them.
Keep me posted!
Best AnswerI had the same issue with my Charge 2. I discovered that selecting a new clock face in the iPhone app resolved the dim issue. I changed to a new face, synced the band, then changed back to the one I prefer and synched again. That seemed to reset and fix the issue for me. Back to full bright display.
I wish I could switch to an apple. Very uphappy with fitbit They can't help this problem.
Best AnswerI’m having the same issue with mine! I followed same instructions and had to cut lights out and only way I could tell was it still vibrates! As much as I paid for this thing I’m horribly upset because I literally got to use it maybe a month!
I can confirm that changing the clock face resolved the issue for my son's fitbit ace 2. I am glad I kept reading. Researched and fixed in under 5 minutes.
Best AnswerI am having the same issue with a dim screen.
It was working fine, but no anymore. I tried all the suggestions you guys have.
Please help.
