10-28-2020
08:28
13:16
10-28-2020
08:28
13:16
It is my understanding that there is a bug-fix in place to resolve the iphone syncing issue that is causing Fitbit Charge 3 to not receive text and phone notifications. Evidently this problem was caused by the latest iphone upgrade. When will this problem be fixed.
A.
11-02-2020 20:00
11-02-2020 20:00
Hope this helps. On your watch you will need to turn off “Do not Disturb” and “Sleep Mode”
On your Watch:
1. Go to Settings
2. Scroll to Do Not Disturb & select off
3. then scroll to Sleep Mode & select off
Once this is done you will start getting the vibrations from calls and texts. (This will not affect your alarm settings. The alarm will still alert you & vibrate.) Also, make sure all notifications are turned on from your Fitbit app.
Plus, if you have an iPhone Go to Settings then Notifications. (Select the app for Phone and Messages and/or any other messenger) Make sure Allow Notifications is on and Show Previews is on Always. As well as Lock Screen, Notification Center, and Banner are all checked with a check marks.
Hope this helps.
