Fitbit Charge 3 will not charge
Hi!
A few months ago I was having difficulty getting my fitbit connected to charge. Last night on top of that issue, the battery shows up on the watch but it won't charge. It stayed at 53% all night. I have restarted it and cleaned it. Anything else I can try? Please help.
1 REPLY 1
@Stacey12 Thanks for stopping by!
Let me help you with your Charge 3 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your device charge.
Let me know how it goes.
Alvaro | Community Moderator
