02-17-2019 12:13 - last edited on 09-06-2020 20:07 by MatthewFitbit
My husbands fit bit is really hard to see, the numbers are very faint, despite it been fully charged, any one know why cheers lynne
Moderator edit: Updated title for clarity
11-29-2020 20:26
11-29-2020 20:26
This did not work for me. I cannot see the Fitbit icon because, well, the display is too dim... 😞
11-29-2020 20:28
11-29-2020 20:28
I submitted an inquiry to Fitbit Support on Twitter and they responded right away. Currently investigating... https://twitter.com/FitbitSupport
05-05-2021 10:28
05-05-2021 10:28
I have this issue often. My brightness display will get bumped to dim by accident. You need to scroll through the setting to brightness and move it back to normal.
05-23-2021 11:06
05-23-2021 11:06
Mine too, @fitbit, you can fix this right??
08-17-2021 21:01
08-17-2021 21:01
Mine too, try restart, charge full , update firmware but Fitbit Charge HR display is still too dim @Fitbit could you fix it
08-17-2021 21:10
08-17-2021 21:10
Fitbit Chrage HR is one of the beautiful tracker that I have seen. But it is irritating to see the brightness of the screen diminishing. When there are so many coming up with the same issue, Fitbit has to respond to it at the earliest. Or the fitbit community has to give an alternate product taking back the old product.
09-20-2021 07:23
09-20-2021 07:23
Hi Ferdinand, I have the same issue with my Charge HR, and restarting doesn't solve the problem. May I kindly ask for your advice on how to address this? Thank You.
11-26-2021 18:35
11-26-2021 18:35
Have the same problem!
01-29-2022 02:51
01-29-2022 02:51
What is the cheaper version? I'm leaving Fitbit due to this, and the previous one I had failed too.
02-06-2022 01:40
02-06-2022 01:40
I have had no response from Fitbit in two years. I have thrown it away - not fit for purpose. Now use an applwa tch.
02-06-2022 02:01
02-06-2022 02:01
I called fitbit. The guy told me swipe right on my screen til I get to
settings. Then under brightness toggle it--somehow it had got itself dim. I
should have reposted after talking to the guy. Don't know why fitbit
doesn't just tell people this. Maybe they only told me since mine was still
under warranty? Maybe they want people forced to buy new? Dunno.
03-22-2022 06:42
03-22-2022 06:42
I'm on my third charge HR. The display on the first two gradually broke up with pixels failing. Both replaced under warranty. But now, although the pixels look okay, the display is now too dim to read easily. I've rebooted, I've toggled the display from Normal to Auto and the problem persists. In Auto display mode, it's totally impossible to read. Bye bye fitbit.
05-21-2022 19:08
05-21-2022 19:08
I've just started using mine again it's been in a cupboard for about 2 years and I'm having the same problem starting to think fitbit has done this on purpose like apple does with old devices making them slower so that you buy a new one instead they've dimmed the light making it useless unless your in a pitch black room 🙄🙄🙄🙄 looks like I'll be switching to another brand of watch 😒
05-22-2022 10:51
05-22-2022 10:51
Recently bought an Apple Watch SE 44mm from John Lewis at £239, the best price I could find and £10 cheaper than the 40mm. Sooooo much better, although I had to switch to an Iphone 13 at the same time. Yes you have to charge it more often, but at least I can read the display. I love that I can see who's at the door on the watch via my Nest doorbell without having to use the phone. My old fitbit looks cheap and tacky in comparison.
05-24-2022 12:19
05-24-2022 12:19
07-08-2022 16:13
07-08-2022 16:13
I actually ended up binning mine and buying the Fitbit luxe, I like the app features on Fitbit and it was on sale and I do prefer a smaller size watch, some them are so bulky, so far I'm happy with it ☺️
07-11-2022 05:43
07-11-2022 05:43
Mine is so dim that I can't see the display in normal daylight. Makes it completely useless as a watch! And to make matters worse, it keeps changing itself to the dim setting (as it wasn't dim enough already!). Several family members with the same model are experiencing the same problem).
I was going to email Fitbit about it but sounds like there is no fix so maybe I should just forget it and buy a new one.
07-14-2022 08:52
07-14-2022 08:52
I agree. I loved my old one but it got lost. Bought a 2nd hand one which was perfect but its just gone dim overnight! Not impressed.
07-14-2022 08:55
07-14-2022 08:55
Hi. Swipe right? In the App? I tried but I can't find 'brightness' anywhere.
07-14-2022 09:18
07-14-2022 09:18
I've just spoken to them about this but it's duff info. Brightness not an option with this tracker. .. my last one was really bright .. this one is too dull.
