09-28-2017
03:01
09:26
09-28-2017
03:01
09:26
I have added Golf to my Account - Charge 2 - exercise shortcuts but when I then go to exercise- timer- track it is only showing walk run or hike. Or if I go to exercise settings the golf shortcut is not showing. Can anyone tell me what I am doing wrong or give me a quick step by step on how I go about adding golf to my exercise and tracking?
09-28-2017 06:30
09-28-2017 06:30
@FitHappyMe Welcome to the Fitbit Community! It's great to have you here! I think you are confusing two different options. The golf tracking option will show on the tracker itself after you have added it on the settings area and synced your tracker. To start it just press the button until you see a sport (usually run) then tap the base of the screen to scroll through the different options finally just long press the button when you see the golf option. The Hike, Run or Walk options are seeing on your app and it is to use the app itself along your phone's gps sensor to record these activities. For more information you can check the Charge 2 manual.
Let me know how it goes!
Best Answer09-28-2017 07:09
09-28-2017 07:09
09-28-2017 07:17 - edited 09-28-2017 07:22
@FitHappyMe Press the button on the tracker itself until you see the Run icon. Now tap the tracker until you see Golf. Press and hold the button on the tracker itself to start/stop.
For additional clarification, when you start/stop the activity from the app -- where the only choices are run, walk and hike -- Fitbit calls that MobileRun. When you start/stop from the tracker, Fitbit calls the Multisport (exercise) mode.
Laurie | Maryland
09-28-2017 07:18
09-28-2017 07:18
Hello @FitHappyMe, the Charge 2 only has one button. Tap the button on the Chatge 2 until you get to the exercise menu..If the exercise listed is not Golf, tap the screen until Golf shows. Now hold in the button to start or stop the recording of.the Gulf event.
09-28-2017 07:21
09-28-2017 07:21
@FitHappyMe Don't worry, this is why I am here. The button I mentioned is the one on your tracker. There you will find the golf option. You can find the instructions here.
Keep me posted!
Best Answer09-28-2017 07:26
09-28-2017 07:26
09-28-2017 08:03
09-28-2017 08:03
@FitHappyMe glad to hear that you found the Golf option on your tracker. Now keep all those steps up!
I'll be around!
Best Answer03-23-2019 07:34
03-23-2019 07:34
I have a golfers group if you would like to join
