09-25-2017
16:48
09:26
09-25-2017
16:48
09:26
new charge 2 is counting ridiculous number of floors that were not climbed. Should be 8, showing 63. Is there an adjustment that can be made somewhere. Old charge hr was very accurate.
Moderator edit: format
09-26-2017
06:34
12:48
09-26-2017
06:34
12:48
Hey @Lms1428, it is cool to see new members around!
Let me ask you a couple of things, how is the weather where you are? Is it windy? I'm asking because the Fitbit that track floors have an altimeter which is the mechanism that records them, and they detect the changes in the atmospheric pressure and that is how the detect your floors, so if there is a windy environment, that will be tracked as floors. Also, if for example you are running or walking uphill, your tracker is gonna record floors. Something that is also very common, is that some users leave their trackers close to a fan for example for all night long and that will cause the Charge 2 to track floors that you actually didn't climb. So I'd like you to take into consideration all of those factors at the moment you see your floors tracked. If none of them apply, I'd suggest you to perform a restart of your Charge 2.
Let me know how it goes!
Tried restarting charge 2 three times, nothing changed. I get up in the morning, walk down the hall about 12 feet and it records 3 to 5 floors. Today I spent most of the day in my kitchen canning tomatoes and it is showing 68 floors. I haven't done any of the things you listed, have a bum knee right now so don't do any more walking than I have to. I think I should return the Charge 2. Never had any issues with my Charge HR.
Thanks for getting back to me @Lms1428! Let me suggest you something else, try to set up your Charge 2 as a new device again by following these instructions:
Use your tracker for a few days and let me know if still tracking extra floors.
10-06-2017
07:06
12:48
Hi @Lms1428! Something that could be affecting the altimeter on your tracker and of course the floors recorded, is the cleaning of it. So please take a look at the following tips to clean your tracker:
Give it a shot and let me know how it goes!
I have reset it several times ,restarted my phone , uninstalled it everything I can think of , it won’t sync still . It just sits and spins
Hey @Trish49, it is nice to see new faces around! If your Charge 2 doesn't seem to be syncing with your iOS device, then I suggest you to try to follow these instructions to make it work:
- Turn OFF the Bluetooth on your phone
- Reboot your phone
- Log out and log in to your Fitbit account
- Turn ON the Bluetooth on your phone
Let me know if that works! 😉
My Charge 2 needs time corrected. However, anyone trying to help assumes I have a smart phone, which I do NOT. My fitbit is working "off of" my husband's smart phone, since he is near enough for that. Any recommendations so at have assumed. I'm beginning to long for the good old days with a winder and moving hands to reset time
Thanks
Delhmor
Best AnswerHello HeyDyFitbit
I've followed your instructions but they fail at the power up screen.
The tracker does not show any lights at all even when I tap it.
It was fully charged before I tried to restart it so I'm assuming that is still its status but it is impossible to tell from the tracker itself.
If I plug it into power supply all the lights flash simultaneously
if I continue the onscreen process it just show some searching.
What else is there to do please?
Best AnswerSo Frustrating! I can not sync my new FITBIT Charge 2. I have followed Instructions, and it is still not happening. I can not find the account icon on my Dashboard!!
Thanks for stopping by @RosaBelle5! I was about to create a support case on you behalf, but I just saw that you have been in touch with our Support Team. Please keep a lookout in your inbox, someone will be in contact with you soon!
Welcome to the Community Forums @APMN! Are you still having syncing issues? Syncing difficulty is usually caused by a missing requirement. Verify each requirement before moving on to the troubleshooting steps.
Depending your phone, these tips might make syncing easier:
If your Fitbit device still won't sync, try these steps:
Give this a go and let me know the outcome!
That didn’t work for me.
06:58
12:47
08-20-2018
06:58
12:47
Hey @muldoonmay, welcome aboard! Let me ask you this, are you having syncing issues with your Charge 2 or is it counting too many floors? Or both? Let me know so I can help you out better!
Have a nice day!
Best AnswerI was having charging issues. Then the counting floors started. I used rubbing alcohol to clean the back and restarted it again but still too many floors.
10:29
12:47
08-20-2018
10:29
12:47
Thanks for your reply @muldoonmay! Thanks for trying some tips to fix this issue with your Charge 2 tracking so many floors. Let me ask you this, by any chance have you left your Fitbit close to a fan? I'm asking because the altimeter on the Charge 2 is sensor that calculates altitude based on atmospheric pressure. Though your device is designed to look for pressure changes based on elevation gains, pressure changes due to other causes—such as a gust of wind, a weather change, or opening a door—can occasionally cause your device to register extra floors. So please keep that in mind but if the issue persists, let me know.
I'll be around!
