08-03-2022
02:17
14:04
08-03-2022
02:17
14:04
I have no flashing green light so it is not doing my heart rate at night so can't do my sleep score
Can anyone help please
Thanks
08-03-2022 03:22
08-03-2022 03:22
Hi, @shazza1962 , have you checked to see if HR detection has been accidentally turned off? On your Charge 4 swipe left until you come to the settings app. Tap to open and then swipe up until you come to Heartrate. If it is set to off, tap to toggle back on again.
If the Heartrate is set to On but the green lights are not flashing, tap to turn OFF, wait a moment and then tap again to turn to ON. Hopefully this will reset it.
It is also worth giving your Fitbit a restart as this can fix many issues.
I hope this helps. Welcome to the forums!
08-03-2022 03:34
08-03-2022 03:34
