02-08-2019
13:32
11:22
02-08-2019
13:32
11:22
After changing my Fitbit now has grey vertical lines goin down it .... I have tried to restart it a few times but they are still there ... I have tried to clear data as well .... the battery charge now seems to be goin down really quick .... only got this in Oct on pre-order so still under warranty .... anyone have any other suggestions? Thanks
Update: Now it’s gone red hot at the back and been vibrating loads and now the screen has gone off?? No idea what’s happening ....
06-01-2020 12:45
06-01-2020 12:45
Hi, not sure if this thread is still open but my Fitbit Charge 3 has grey lines on it, I was on a beta and it developed shortly after.
Best Answer06-01-2020 12:57
06-01-2020 12:57
Best Answer06-01-2020 13:16
06-01-2020 13:16
Thanks for your reply, I tried this but it didn’t work. I will contact support as you suggested. Thank you.
Best Answer06-01-2020 13:31
06-01-2020 13:31
I have a line appeared on mine too today. 😔
Best Answer06-01-2020 13:48
06-01-2020 13:48
I’ve tried resetting but nothing works with mine.
Best Answer06-01-2020 16:44
06-01-2020 16:44
There is nothing that can be done. All those restarts do nothing and if you are out of warranty you are done. Apparently these are disposable. So frustrating!
06-01-2020 22:58
06-01-2020 22:58
Really? That’s disappointing if that’s the case.
Best Answer06-04-2020 13:52
06-04-2020 13:52
Hi have a Fitbit Charge 3 purchased in February 2019. Just last night the screen developed vertical faded out gray lines and the touch screen does not respond well to swiping. I've tried all the reset options, long reset, etc. but the problem persists.
I've read through others posting about the same issue and it seems there really is not a fix for this. What are my options please? This seems to be a product defect.
06-04-2020 14:06
06-04-2020 14:06
Best Answer06-04-2020 14:17
06-04-2020 14:17
Best Answer06-04-2020 14:28
06-04-2020 14:28
Best Answer06-04-2020 14:39
06-04-2020 14:39
Best Answer06-04-2020 15:07
06-04-2020 15:07
Hi everyone,
Well guess what?
I have the vertical grey lines problem, which is why I have ended up here!
Mine was bought as a present in December 2018, so as far as I can tell from reading this thread, there is nothing I can do?
That can't be right as its obviously a fault with the product??
06-04-2020 15:17
06-04-2020 15:17
Right?! I've seen a zillion people post about the gray lines. What's up with that? Has to be a product defect. Come on Fitbit!
06-06-2020 15:57
06-06-2020 15:57
I had no trouble when I had to have my first one replaced. The new one came quickly. It was a good experience until I had the trouble with this one and realized that the new one has no warranty so here I am with my 2nd Charge 3 and both together only lasted just over a year. Now do I spend money on a new one??
Best Answer06-06-2020 16:03
06-06-2020 16:03
Best Answer06-20-2020 09:54
06-20-2020 09:54
I’ve tried the restart and it still has the grey lines.
Best Answer06-20-2020 10:36
06-20-2020 10:36
I'm having the same issues with my charge 3 that I got back in October. One day after charging, vertical grey lines appeared on my screen and the touch screen is now nearly unresponsive. I also can't use alarms or timers.
I have tried restarting the device as per the instructions from moderators on this post. Please advise me as to what my options are from here. Thanks in advance
Best Answer06-20-2020 10:41
06-20-2020 10:41
Contact customer support by phone and if it is within the 1 year warranty period they will send you a replacement. If outside they give you a credit towards a new one(25% I believe)
Best Answer06-20-2020 10:42
